By M0ebius
#18120 I have a problem with the ESP8266WebServer.
The helloserver example compiles, uploads and runs - but it does not accept connections.
I always get a connection timeout.
In the file esp8266webserver.cpp, the line "WiFiClient client = _server.available();" never returns a valid client.
But it works, if i implement a server "by hand":
const char* ssid = "....";
const char* password = "...";
WiFiServer server(80);
void setup()
  WiFi.mode(WIFI_STA);
  WiFiStart();
void WiFiStart()
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  server.begin();
void loop()
  if (!client)
    return;
  Serial.println("new client");
  unsigned long ultimeout = millis()+250;
  while(!client.available() && (millis()<ultimeout) )
    delay(1);
  if(millis()>ultimeout)
    Serial.println("client connection time-out!");
    return;
  String sRequest = client.readStringUntil('\r');
  //Serial.println(sRequest);
  client.flush();
 // Send the response to the client
  client.print("header");
  client.print("body");
  // and stop the client
  client.stop();
  Serial.println("Client disonnected");
How can i fix it?
(Win 8.1-64, Arduino 1.6.4 with package 628-545ffde)
