not sure if I'm posting at the correct section but here goes;
I'm trying to get photosensor reading on Ubidots.
I've updated the firmware of the Esp module and the following;
#define SSID "FreeWifi"
#define PASS "b1tchpl3as3"
#define DST_IP "things.ubidots.com"
#define idvariable "557000297625423d2e059974" // replace with your Ubidots Variable ID
#define token "JTV7TqHW7GmDZuQOmb1KASZiYjel62a1PFz7w1rdW4sMjD8xwPY39h06zpmU" // replace with your Ubidots token
int len;
int sensorValue = 0;
int sensorPin = A5;
void setup()
// Open serial communications and wait for port to open:
char cmd[254];
Serial.setTimeout(5000);
//test if the module is ready
Serial.println("AT+RST");
delay(1000);
if (Serial.find("ready"))
//dbgSerial.println("Module is ready");
//dbgSerial.println("Module have no response.");
while (1);
delay (1000);
//connect to the wifi
boolean connected = false;
for (int i = 0; i < 5; i++)
if (connectWiFi())
connected = true;
break;
if (!connected) {
while (1);
delay(5000);
Serial.println("AT+CIPMUX=0");
void loop()
int num = 0;
sensorValue = analogRead(sensorPin);
String var = "{\"sensorValue\":" + String(sensorValue) + "}";
num = var.length();
String cmd = "AT+CIPSTART=\"TCP\",\"";
cmd += DST_IP;
cmd += "\",80";
Serial.println(cmd);
if (Serial.find("Error")) return;
len = strlen ("POST /api/v1.6/datasources/");
len = len + strlen (idvariable);
len = len + strlen ("/values HTTP/1.1\nContent-Type: application/json\nContent-Length: ");
char numlenght[4]; // this will hold the length of num which is the length of the JSON element
sprintf(numlenght, "%d", num); // saw this clever code off the net; works yay
len = len + strlen (numlenght);
len = len + num; //fixed length of the string that will print as Content-Length: in the POST
len = len + strlen ("\nX-Auth-Token: ");
len = len + strlen (token);
len = len + strlen ("\nHost: things.ubidots.com\n\n");
len = len + strlen ("\n\n");
Serial.print("AT+CIPSEND=");
Serial.println (len); //lenght of the entire data POST for the CIPSEND command of ESP2866
//Serial.println(cmd.length());
if (Serial.find(">"))
//Serial.print(">");
} else
Serial.println("AT+CIPCLOSE");
delay(1000);
return;
Serial.print ("POST /api/v1.6/variables/");
Serial.print (idvariable);
Serial.print ("/values HTTP/1.1\nContent-Type: application/json\nContent-Length: ");
Serial.print (num);
Serial.print ("\nX-Auth-Token: ");
Serial.print (token);
Serial.print ("\nHost: things.ubidots.com\n\n");
Serial.print (var);
Serial.println ("\n\n");
delay(9000);
//Serial.find("+IPD"); clear the input buffer after the web site responds to the POST
while (Serial.available())
char c = Serial.read();
delay(1000);
boolean connectWiFi()
Serial.println("AT+CWMODE=1");
String cmd = "AT+CWJAP=\"";
cmd += SSID;
cmd += "\",\"";
cmd += PASS;
cmd += "\"";
delay(2000);
if (Serial.find("OK"))
return true;
} else
return false;
}I got this on my serial monitor and it just stuck like so;
Any idea why is it so?
thanks in advance.
