- Tue Jul 14, 2015 8:25 pm
#23285
Sketch is Standard Blink with Pin 2
Code: Select all#define LED 2
// the setup function runs once when you press reset or power the board
// initialize digital pin 13 as an output.
pinMode(LED, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(LED, HIGH); // turn the LED on (HIGH is the voltage level)
delay(100); // wait for a second
Serial.println("LOOP");
digitalWrite(LED, LOW); // turn the LED off by making the voltage LOW
} I am using Arduino 1.6.5
using Manager URL =
http://arduino.esp8266.com/package_esp8 ... index.jsonInstall Board Manager ESP6288
Sketch uses 203,120 bytes (38%) of program storage space. Maximum is 524,288 bytes.
Uploading 31760 bytes from /var/folders/ng/mxyvxczs5t96qsp0wy47m8l80000gn/T/build6647629209626918089.tmp/sketch_jul14b.cpp_00000.bin to flash at 0x00000000
Uploading 171400 bytes from /var/folders/ng/mxyvxczs5t96qsp0wy47m8l80000gn/T/build6647629209626918089.tmp/sketch_jul14b.cpp_10000.bin to flash at 0x00010000
Flash completes and Blink on GPIO2 is running.
VCC, GND connected
RX,TX connected (obvious)
GPIO2 (LED pin 2) to LED
VCC -> CP_PD (I undo this each time I flash, otherwise receive error)
GND -> GPIO_0 (I assume this again is required for Flashing if i remember correctly.
No connection -> RST
I would sent a picture, but i use similar colors on the pins.
Should I remove or take GPIO_0 to High and RST -> GND to restart it?
