M.KATHIRESAN
M.KATHIRESAN
Explore... Chat... Share...
File dataFile = SD.open("/path/file");
if(server.streamFile(dataFile,"image/jpeg") != dataFile.size()) {
Serial.printLn("Did not stream entire file, maybe file path not correct!");
dataFile.close(),It takes about 20-25 seconds for home assistant c[…]
