By DaniloFix
#26856 Hi
I'm building a sensor that needs to be powered off most of the time. Only when a reset is done from switch, it should run some code and power off again. I want to power off because it uses less power. It only needs to run 2 - 3 times a week for 5-10 seconds.
According to http://bbs.espressif.com/viewtopic.php?f=6&t=133 the ESP uses 20 times less power in "power off" state, than in deep sleep. Running on battery, this is important :-)
But how do I turn if off (while not disconnecting the battery off course) ?
Thanks
By DaniloFix
#26857 Just found this from another forum by a user called janisalnis (thanks mate)...
Hi!
Thanks for your interest about CH_PD pin.
I have wired it directly to Arduino. Without pulll up resistor. Below are some relevant lines from the code.
Code: Select all#define CH_PD_PIN 4
pinMode(CH_PD_PIN, OUTPUT);
digitalWrite(CH_PD_PIN, 1); // bring up ESP8266 from power-down mode. It resets.
digitalWrite(CH_PD_PIN, 0);  // activate PD power-down pin of ESP8266
By Barnabybear
#26858
DaniloFix wrote:Hi
Thanks
Hi, this should be a good starting point. http://www.esp8266.com/viewtopic.php?f=11&t=4458
