i look for method get current state for output gpio PWM-ed... similar "analogRead(gpio)" for analog input
via wire or direct via system (core) register's...
Explore... Chat... Share...
martinayotte wrote:Do you means to read back the analog value of your analog output generated using PWM ?
Yes, you can, but you need first to filter out the PWM to make it a real steady analog output using resistor and capacitor, and secondo, you need to scale down the range so it can fit within the 0-1V range of the ADC.
