Seeed nodeMCU_v2
MacOS 10.9.5
Arduino IDE 1.6.7
Board: nodeMCU 1.0…
CPU Frequency: 80 MHz
Flashsize: 4M…
UploadSpeed: 115200
Port: /dev/cu.SLAB_USBtoUART
File: nodedMCUBlink (from Adafruit)
Error:
warning: espcomm_send_command: didn't receive command response
warning: espcomm_send_command(FLASH_DOWNLOAD_DATA) failed
This same nodeMCU was working fine with ESPlorer (same port, same cable) before I tried to use
Arduino IDE.
I hold the Flash button down and then click Reset buttton. No LEDs are on. I see the blue LED on the ESP board flash while uploading. Also tried holding the
Flash button while plugging the USB cable. Sometimes the IDE just hangs during the upload.
