If it's not possible to have two ports open at once, I'm wondering if I can use a single port, and somehow distinguish between http GETs or command string responses and direct to the appropriate web server or serial string processing in my code (although I guess this requires two clients connected to the same port at once which isn't possible?)
My knowledge of this stuff is limited, so any thoughts would be much appreciated! I'm trying to use and ESP8266 to replace an Ethernet Shield which allows me to do the following:
EthernetServer cmdserver(9999);
EthernetClient cmdclient;
EthernetServer webserver(80);
EthernetClient webclient;
Many thanks,
Richard
