By DinoN
#43485 Arduino 1.6.8
ESP library 2.1 installed
Uploaded BasicOTA.ino sketch from example to the NodeMCU using usb connection all done correctly
After sone time I can see NodeMCU under ports with valid IP, when executing OTA update from arduino I am getting:
[ERROR]: Error Uploading
I conected to NodeMCU using serial port to see what is happening, I am getting IP address correctly, OTA starts and suddenly ends, this is serial console log:
Progress: 0%
Progress: 0%
Progress: 0%
Error[4]: End Failed
Any ideas what seems to be wrong
thanx,
D
By krzychb
#43492 Hi DinoN,
I recently had similar issue except upload was failing each time after 2% completion.
Using esptool I have completely erased flash and the issue was resolved.
Hope this helps you as well :D
If you are able to try it then please post your results.
Krzysztof
