- Sat Apr 16, 2016 2:57 am
#45572
gpio16 is a little bit different as it has an internal pulldown resistor.
depending on the pin-setup and your hw you may need an external pullup.
or maybe it is just because, as the espressiv doc says, it is not a standard API GPIO :
Code: Select all2.5. GPIO16 related APIs Different from other IO interfaces, GPIO16(XPD_DCDC) belongs to the RTC module instead of the general GPIO module. It can be used to wake up the chip during deep-sleep; it can be configured to input or output mode; but it cannot trigger the IO interrupt. the APIs are shown below.
2.5.1. gpio16_output_conf(void)
Set the GPIO16 to the output mode.
2.5.2.gpio16_output_set(uint8 value)
Output high/low level from GPIO16. Configure GPIO16 to the output mode first.
2.5.3.gpio16_input_conf(void)
Set the GPIO16 to the input mode.
2.5.4.gpio16_input_get(void)
Read the GPIO16 input level status. Configure GPIO16 to the input mode first.
