The sketch loads to the ESP8266 and works just fine. If I run the same sketch on the Arduino Uno, I don't even get the warning.
Here is a very simple code example that produces the warning (actually twice):
void functionToPassTo(char* someString){
//some code
functionToPassTo("Hello");
functionToPassTo("GoodBy");
}It seems the proper way to do this is as follows:
//some code
char passToFunction_1[] = "Hello";
functionToPassTo(passToFunction_1);
char passToFunction_2[] = "GoodBy";
functionToPassTo(passToFunction_2);
That's a lot more code. If I use the "proper method" I would have to create about 30 variables to handle all my function calls.
Is there any hidden danger of using the code that produces the compiler warnings?
Thanks and regards
