Can someone help me to resolve my problem plz
I'm using an arduino UNO with an esp8266 wifi shield. My goal in this project is to send data collected by a LM35 temperature sensor to Thingspeak platform.
When I use esp8266 with no sketch ( empty setup() & loop() ) and I configure it manualy via AT commands using usb and Serial .. it works, and I can connect to my WiFi network ..
The problem appears when I want to use a sketch over adruino ( to connect and upload data to Thingspeak ) .. WiFi.status() returns WL_NO_SHIELD and even if I try to use AT commands inside the sketch it's not working (e.g. Serial.write("AT"); doesn't return "OK" )
Thank you ..
