frankygoop wrote:Hello, I have tried several codes with all possible options with EEPROM " put" and " get" and work fine with Address 0, but wont work with any different address.
I am on board ESP8266 3.1.1,
I tried several older board version down to 2.5.0 and IDE version 1.8.16. nothing works.
Any advise is welcome.
Thank you
Updated*****
I found that in order to write into another address, the EEPROM.begin(XXX) need to include the total amount of necessary memory covering all possible addresses starting from 0 that you expect to write. I mean you can not do two separate EEPROM.begin. Is that the normal behavior?
Did you found any solution? I have the same issue in Arduino IDE v1.8.2 and ESP8266 Core v2.3.0
