@Sprite_tm...
The 'Cross Eyed Kitten' pic in your demo, is it a pic you found on the Net or
is this guy closer too Home..?
Name..?
Explore... Chat... Share...
Moderator: Sprite_tm
Sprite_tm wrote:Just a FYI: I have developed httpd and the mkespfs stuff, but I can only develop/test it under Linux; I don't do Windows. If someone figures a way to make things work in Windows, please post them here; same goes for patches that make Windows-support easier. Don't go expecting Windows-support from me, though; I'll just advise you to install Linux
folny82 wrote:Hi
Compilation file webpages.espfs I had to use VirtualBox and Linux compilation is successful then I used the command make webpages.espfs but it would be great if it worked under Windows.
