Moderator: Sprite_tm
I'm playing with the code, but compiling from the main source I get an error when scanning for networks in the page wifi.tpl:
Con req, conn=0x3fff3eb0, pool slot 0
URL = /wifi/wifi.tpl
Is url index 8
Heatshrink compressed file; decode parms = b4
Conn 0x3fff3eb0 is done. Closing.
Con req, conn=0x3fff40a8, pool slot 0
URL = /wifi/style.css
Is url index 10
Con req, conn=0x3fff4268, pool slot 1
URL = /wifi/140medley.min.js
Is url index 10
Conn 0x3fff40a8 is done. Closing.
Conn 0x3fff4268 is done. Closing.
Con req, conn=0x3fff4388, pool slot 0
URL = /wifi/wifiscan.cgi
Is url index 7
Fatal exception (28):
epc1=0x402411a9, epc2=0x00000000, epc3=0x00000000, excvaddr=0x000000aa, depc=0x00000000
And then the device resets. The module can only see one network, so I don't think it's an overflow..
Gipmad: You're Mastro Gippo, if I'm not mistaken? Yeah, last CCC was a blast, and I don't have any bad memories of the Grappa
Hmm, I don't have had that error yet... but the wireless scan result gathering is a bit flakey in general. I'll see what I can do. In the meanwhile, it may help to run arm-xtensa-whatever-objdump -S on the elf file that's generated and see what's at the SP in the error message. (Sorry for not being clearer, I don't have the SDK installed here.)
I never did that kind of debugging before, but I tried; I "randomly" looked up on the generated file. I couldn't find epc1=0x402411a9, I guess they are cpu registers. By looking at excvaddr=0x000000aa, I found the probable culprit (line "aa"):
//Copy access point data to the static struct
n=0;
bss_link = (struct bss_info *)arg;
while (bss_link != NULL) {
9c: 000e86 j da <wifiScanDoneCb+0xae>
9f: 380000 excw
cgiWifiAps.apData[n]=(ApData *)os_malloc(sizeof(ApData));
a2: e01c movi.n a0, 30
a4: fe .byte 0xfe
a5: 33fa11 l32r a1, fffcd090 <tplWlan+0xfffccc3c>
a8: 222c movi.n a2, 34
aa: 0139 s32i.n a3, a1, 0
ac: ffdd01 l32r a0, 20 <wifiScanDoneCb-0xc>
Thank you for pointing me to the right path; I have to do some "real" work now, I will try to place some printf to debug these lines when I get some more spare time!
