ESP8266 Webserver Project
Moderator: Sprite_tm
By alonewolfx2
#13941
admin wrote:Be cool if was a standalone webserver maybe with SD card attached? :-) Dreaming....
Richard.
+1 Sd card. Dreaming.. :)
By kewlape
#14639 Thanks for your response sprite_tm. The reason I asked for the firmware is , its the best way for me to easily update the esp8266 and test it out before I can start tinkering with it. Even something as simple as updating the firmware is a learning step for me. Hence using the compiled firmware and seeing a hotspot allows me with a starting point.
I did see others requesting the same on the other thread. If it is not available, that's ok, its a further opportunity for me to learn. Appreciate the hard work.
By banitama
#15192
Richard.
SD Card is nice. At least we can save some configuration file, log, etc.
+1
By dexterkhm
#23020 Hello! I am using ESPHTTPD in my progect , i made a web form to connect to local WIFI AP also i made for for changing station IP and even connected ds18b20 and everything is perfect till now. I wish to connect to thingspeak. I copied files httpclient.c httpclient.h from example "DHT22 ThingSpeak" i take it from SDK examples. And I get many errors
Image I think the problem is in make file settings but i do not know where exactly. So maybe there is a sample progect Httpd + http client+thingspeak?
