ESP8266 Webserver Project
Moderator: Sprite_tm
By CheapB
#3221
bkrajendra wrote:
Code: Select allRajendra@Rajlapy /cygdrive/d/ESP8266/Projects/esp8266/esp_iot_sdk_v0.9.2/app
$ make htmlflash
make -C mkespfsimage
make[1]: Entering directory '/cygdrive/d/ESP8266/Projects/esp8266/esp_iot_sdk_v0.9.2/app/mkespfsimage'
cc -I ../lib/heatshrink -std=gnu99   -c -o main.o main.c
make[1]: cc: Command not found
<builtin>: recipe for target 'main.o' failed
make[1]: *** [main.o] Error 127
make[1]: Leaving directory '/cygdrive/d/ESP8266/Projects/esp8266/esp_iot_sdk_v0.9.2/app/mkespfsimage'
Makefile:127: recipe for target 'mkespfsimage/mkespfsimage' failed
make: *** [mkespfsimage/mkespfsimage] Error 2
can anyone help me. I'm stuck from last two days.
All other project works properly
Even I get firmware 00000.bin and 40000.bin ... but command for "make htmlflash" not working
I guess its required to flash html file into the ESP.
Please help!!!
do you have heatshrink installed?
By martinayotte
#3222 @bkrajendra, your main problem is that the xtensa compiler isn't found :
Code: Select allcc -I ../lib/heatshrink -std=gnu99   -c -o main.o main.c
Verify in the root Makefile that you have proper path to CrossTool-NG :
XTENSA_TOOLS_ROOT ?= /opt/Espressif/crosstool-NG/builds/xtensa-lx106-elf/bin
Is your SDK at the proper place ?
Since the compiler/linker/etc are defined as :
# select which tools to use as compiler, librarian and linker
CC := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-gcc
AR := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-ar
LD := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-gcc
Verify that the resulting paths for those binaries are there :
/opt/Espressif/crosstool-NG/builds/xtensa-lx106-elf/bin/xtensa-lx106-elf-gcc
/opt/Espressif/crosstool-NG/builds/xtensa-lx106-elf/binxtensa-lx106-elf-ar
Hope this helps,
By bkrajendra
#3283
Dear martinayotte and others
Problem Solved ! (?)
Hey thank you very much for help.
Actually everything was ok. XTENSA_TOOLS_ROOT was proper, gcc was there. all ok.
basically I was trying all this in windows with cygwin32 and cygwin64.
Normal compiling of all other apps do work.
But my problem was only with "mkespfsimage" FS image making (webpages.espfs) was not working.
I tried in lubuntu image also but same problem was there.
Finally I followed guide at:
https://github.com/esp8266/esp8266-wiki/wiki/Toolchain
Earlier also I left this crosstool-NG because of 'libexpat' not found in lubuntu.
But then It got resolved by installing "libexpat-dev"
So now I'm able to generate webpages.espfs image on CrossTool.NG.
But 'make' still giving me error. I guess it must be a problem of LIBs.
But for now I resolved it by executing make in Cygwin to get 0x00000.bin and 0x40000.bin
And for Image generation I have to go to lubuntu (CrossTool.NG.)
Now error i get during normal make in (lubuntu) CrossTool.NG. is as:
Code: Select allesp8266@esp8266-VirtualBox:/opt/Espressif/esphttpd$ make
CC user/cgi.c
CC user/cgiwifi.c
CC user/espfs.c
CC user/heatshrink_decoder.c
CC user/httpd.c
CC user/httpdespfs.c
CC user/io.c
CC user/stdout.c
CC user/user_main.c
AR build/httpd_app.a
LD build/httpd.out
/opt/Espressif/ESP8266_SDK/lib/libmain.a(app_main.o): In function `read_macaddr_from_otp':
(.irom0.text+0x7c): undefined reference to `wDev_ProcessFiq'
(.irom0.text+0x84): undefined reference to `lmacInit'
(.irom0.text+0x88): undefined reference to `wDev_Initialize'
(.irom0.text+0x8c): undefined reference to `pp_attach'
(.irom0.text+0x98): undefined reference to `pm_attach'
(.irom0.text+0x9c): undefined reference to `wDevEnableRx'
(.irom0.text+0xe3): undefined reference to `lmacInit'
(.irom0.text+0xec): undefined reference to `wDev_Initialize'
(.irom0.text+0xf2): undefined reference to `pp_attach'
(.irom0.text+0x115): undefined reference to `pm_attach'
(.irom0.text+0x126): undefined reference to `wDevEnableRx'
/opt/Espressif/ESP8266_SDK/lib/libmain.a(user_interface.o): In function `os_printf':
(.irom0.text+0x58): undefined reference to `pm_is_open'
(.irom0.text+0x5c): undefined reference to `pm_is_waked'
(.irom0.text+0x60): undefined reference to `pm_post'
(.irom0.text+0x6d): undefined reference to `pm_is_open'
(.irom0.text+0x93): undefined reference to `pm_is_waked'
(.irom0.text+0xba): undefined reference to `pm_post'
(.irom0.text+0x13c): undefined reference to `pm_is_waked'
(.irom0.text+0x144): undefined reference to `pm_is_open'
(.irom0.text+0x1d8): undefined reference to `pm_post'
(.irom0.text+0x204): undefined reference to `ppRecycleRxPkt'
(.irom0.text+0x20d): undefined reference to `ppRecycleRxPkt'
/opt/Espressif/ESP8266_SDK/lib/libmain.a(user_interface.o): In function `system_upgrade_reboot':
(.irom0.text+0x390): undefined reference to `pm_rtc_clock_cali_proc'
(.irom0.text+0x394): undefined reference to `pm_set_sleep_time'
/opt/Espressif/ESP8266_SDK/lib/libmain.a(user_interface.o): In function `system_deep_sleep':
(.irom0.text+0x4aa): undefined reference to `pm_rtc_clock_cali_proc'
(.irom0.text+0x4b2): undefined reference to `pm_set_sleep_time'
/opt/Espressif/ESP8266_SDK/lib/libmain.a(user_interface.o): In function `system_print_meminfo':
(.irom0.text+0x6ad): undefined reference to `pm_rtc_clock_cali_proc'
/opt/Espressif/ESP8266_SDK/lib/libmain.a(user_interface.o): In function `wifi_softap_set_config':
(.irom0.text+0x14f0): undefined reference to `pm_set_sleep_type_from_upper'
(.irom0.text+0x1501): undefined reference to `pm_set_sleep_type_from_upper'
/opt/Espressif/ESP8266_SDK/lib/libphy.a(phy_chip_v6.o): In function `chip_v6_rxmax_ext':
(.irom0.text+0x2424): undefined reference to `uart_tx_flush'
(.irom0.text+0x242d): undefined reference to `uart_tx_flush'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_hostap.o):(.irom0.text+0x10): undefined reference to `ppTxPkt'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_hostap.o):(.irom0.text+0xea): undefined reference to `ppTxPkt'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_hostap.o):(.irom0.text+0x330): undefined reference to `ic_bss_info_update'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_hostap.o):(.irom0.text+0x334): undefined reference to `ppRegisterTxCallback'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_hostap.o):(.irom0.text+0x363): undefined reference to `ic_bss_info_update'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_hostap.o):(.irom0.text+0x37a): undefined reference to `ppRegisterTxCallback'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_hostap.o): In function `hostap_handle_timer':
(.irom0.text+0x509): undefined reference to `ppRecycleRxPkt'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_hostap.o): In function `hostap_input':
(.irom0.text+0xd3b): undefined reference to `ppTxPkt'
(.irom0.text+0xd70): undefined reference to `ic_set_vif'
(.irom0.text+0xdd3): undefined reference to `ic_set_vif'
(.irom0.text+0xe68): undefined reference to `esf_buf_recycle'
(.irom0.text+0xf00): undefined reference to `ic_bss_info_update'
(.irom0.text+0xf10): undefined reference to `ic_set_vif'
(.irom0.text+0xf23): undefined reference to `esf_buf_recycle'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_ht.o): In function `ieee80211_add_htinfo_vendor':
(.irom0.text+0x90c): undefined reference to `rc_get_trc_by_index'
(.irom0.text+0xa4e): undefined reference to `rc_get_trc_by_index'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_input.o): In function `ieee80211_deliver_data':
(.irom0.text+0x56): undefined reference to `ppRecycleRxPkt'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_output.o):(.irom0.text+0x8): undefined reference to `esf_buf_alloc'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_output.o): In function `ieee80211_output_pbuf':
(.irom0.text+0x92): undefined reference to `esf_buf_alloc'
(.irom0.text+0xce): undefined reference to `esf_buf_recycle'
(.irom0.text+0x1a1): undefined reference to `rc_get_trc_by_index'
(.irom0.text+0x255): undefined reference to `ppTxPkt'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_output.o): In function `ieee80211_mgmt_output':
(.irom0.text+0x495): undefined reference to `ppTxPkt'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_output.o): In function `ieee80211_send_nulldata':
(.irom0.text+0x5cf): undefined reference to `rc_get_trc_by_index'
(.irom0.text+0x5de): undefined reference to `ppTxPkt'
(.irom0.text+0x72b): undefined reference to `esf_buf_recycle'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_output.o): In function `ieee80211_send_probereq':
(.irom0.text+0xb7f): undefined reference to `ppTxPkt'
(.irom0.text+0xb92): undefined reference to `rc_get_trc_by_index'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_output.o): In function `ieee80211_getcapinfo':
(.irom0.text+0xcb4): undefined reference to `esf_buf_recycle'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_output.o): In function `ieee80211_send_mgmt':
(.irom0.text+0xe65): undefined reference to `rc_get_trc_by_index'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_output.o): In function `ieee80211_alloc_proberesp':
(.irom0.text+0x1499): undefined reference to `rc_get_trc_by_index'
(.irom0.text+0x14a9): undefined reference to `ppTxPkt'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_power.o): In function `ieee80211_pwrsave':
(.irom0.text+0x90): undefined reference to `esf_buf_recycle'
(.irom0.text+0xfa): undefined reference to `ppTxPkt'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_proto.o): In function `ieee80211_proto_attach':
(.irom0.text+0x1e): undefined reference to `ppRegisterTxCallback'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_scan.o): In function `ieee80211_scan_attach':
(.irom0.text+0x90): undefined reference to `pm_scan_lock'
(.irom0.text+0xb9): undefined reference to `pm_is_open'
(.irom0.text+0xc2): undefined reference to `pm_is_waked'
(.irom0.text+0xcc): undefined reference to `pm_post'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_scan.o): In function `scan_start':
(.irom0.text+0x100): undefined reference to `pm_scan_lock'
(.irom0.text+0x2cb): undefined reference to `ppTxPkt'
(.irom0.text+0x36c): undefined reference to `wDev_SetRxPolicy'
(.irom0.text+0x370): undefined reference to `pm_force_scan_unlock'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_scan.o): In function `scan_cancel':
(.irom0.text+0x3e7): undefined reference to `wDev_SetRxPolicy'
(.irom0.text+0x3f9): undefined reference to `wDev_SetRxPolicy'
(.irom0.text+0x430): undefined reference to `pm_is_open'
(.irom0.text+0x438): undefined reference to `pm_force_scan_unlock'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_scan.o): In function `scan_remove_probe_ssid':
(.irom0.text+0x69c): undefined reference to `ppCheckTxIdle'
(.irom0.text+0x6ab): undefined reference to `ppCheckTxIdle'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_sta.o): In function `ieee80211_sta_new_state':
(.irom0.text+0x2a8): undefined reference to `ppRecycleRxPkt'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_sta.o): In function `ieee80211_parse_wmeparams':
(.irom0.text+0x8fc): undefined reference to `ic_bss_info_update'
(.irom0.text+0xb0f): undefined reference to `ic_set_vif'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(wl_cnx.o): In function `cnx_attach':
(.irom0.text+0x3e): undefined reference to `ppRegisterTxCallback'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(wl_cnx.o): In function `cnx_sta_connect_cmd':
(.irom0.text+0x125): undefined reference to `wDev_SetRxPolicy'
(.irom0.text+0x136): undefined reference to `wDev_SetRxPolicy'
(.irom0.text+0x1c5): undefined reference to `wDev_SetRxPolicy'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(wl_cnx.o): In function `cnx_start_handoff_cb':
(.irom0.text+0x5b0): undefined reference to `wDev_remove_KeyEntry'
(.irom0.text+0x5dc): undefined reference to `wDev_remove_KeyEntry'
(.irom0.text+0x5e4): undefined reference to `wDev_remove_KeyEntry'
(.irom0.text+0x5ec): undefined reference to `wDev_remove_KeyEntry'
(.irom0.text+0x5f4): undefined reference to `wDev_remove_KeyEntry'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(wl_cnx.o): In function `cnx_rc_update_rssi':
(.irom0.text+0xdc4): undefined reference to `ic_set_sta'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(wl_cnx.o): In function `cnx_rc_update_state_metric':
(.irom0.text+0xdf2): undefined reference to `ic_set_sta'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(wl_cnx.o): In function `cnx_update_bss':
(.irom0.text+0xeb3): undefined reference to `ic_set_sta'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(wl_cnx.o): In function `cnx_sta_leave':
(.irom0.text+0x1097): undefined reference to `ic_set_sta'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(wl_cnx.o): In function `cnx_sta_associated':
(.irom0.text+0x1186): undefined reference to `ic_set_sta'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_ets.o): In function `ieee80211_getmgtframe':
(.irom0.text+0x31): undefined reference to `esf_buf_alloc'
/opt/Espressif/ESP8266_SDK/lib/libwpa.a(wpa_auth.o):(.irom0.text+0xc): undefined reference to `ic_remove_key'
/opt/Espressif/ESP8266_SDK/lib/libwpa.a(wpa_auth.o):(.irom0.text+0x10): undefined reference to `ic_set_key'
/opt/Espressif/ESP8266_SDK/lib/libwpa.a(wpa_auth.o):(.irom0.text+0x74): undefined reference to `ic_remove_key'
/opt/Espressif/ESP8266_SDK/lib/libwpa.a(wpa_auth.o):(.irom0.text+0xd6): undefined reference to `ic_set_key'
/opt/Espressif/ESP8266_SDK/lib/libwpa.a(wpa_main.o):(.irom0.text+0x1f): undefined reference to `ic_set_key'
/opt/Espressif/ESP8266_SDK/lib/libwpa.a(wpa_main.o): In function `eagle_auth_done':
(.irom0.text+0x2ae): undefined reference to `ppRegisterTxCallback'
make: *** [build/httpd.out] Error 1
Friends... let me know if anyone have any guess..!
By martinayotte
#3289 @bkrajendra, did you try to compile with sdk_v0.9.2 or sdk_v0.9.3 ?
Because it seems that many of the undefined mentioned are located in libphy.a in 0.9.2 are now moved in libpp.a in 0.9.3.
In this case, you only need to add "pp" to LIBS of the esphttpd Makefile.
