rvbcrs wrote:Wow great work! As I'm still not able to build a flash file with the SDK is it possible for someone to create flashable files with the bootstrap site?
Find compiled firmware.zip in git repo at
https://github.com/IOCare/esp8266GUI
Explore... Chat... Share...
Moderator: Sprite_tm
bkrajendra wrote:rvbcrs wrote:Wow great work! As I'm still not able to build a flash file with the SDK is it possible for someone to create flashable files with the bootstrap site?
Hi there - I noted the compiled files - one to blow at 0, another to blow at 0x40000 - but where do you put the last file and how??
