I'm a newbie and had a quick question.
Is there a simple way to have both the convenience of setting up the network SSID as descibred here
http://harizanov.com/2014/11/esp8266-po ... r-reading/
and easy integration via MQTT.
Regards
Explore... Chat... Share...
Moderator: Sprite_tm
