'm ESP novice and would like to use multiple ESP8266.
Is there a way to change the default IP address 192.168.4.1?
So that i can use different ESP-Link units can respond.
Best regards
kwalter
Explore... Chat... Share...
Moderator: Sprite_tm
rayellam wrote:I have successfully flashed ESP-Link on my ESP-12E but im struggling to find ANY documentation on how to use it. Is there any document that lists serial commands? the SLIP protocol implemented in ESP-Link? and anything else?
I see there are plenty of bits of code out there for Arduino but i will implement my use on a PIC16 micro so i need to write some lib's to get the thing working and i need as much info on the "nuts+bolts" in ESP-Link to do this.
I have posted a duplicate thread general discussions.
Many thanks
Ray
bigG wrote:32Mbit / 4Mbyte module you set blank.bin to 0x3FE000
and
4Mbit / 512Kbyte module you set blank.bin to 0x7E000
I have a 16Mbit / 2Mbyte module. So what address should I set it to.
