ESP8266 Webserver Project
Moderator: Sprite_tm
By Tinamore
#26638 Hi
Thanks Sprite_tm for Great Project.
I flash ESP-HTTPD but httpd run unStable. Esp8266-12E loop show error below and not into http server :?
Ready
mode : sta(18:fe:34:a6:82:b6)
add if0
f 0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 3
pm open phy_2,type:2 0 0
cnt
Fatal exception (28):
epc1=0x4000deed, epc2=0x00000000, epc3=0x00000000, excvaddr=0x0000000f, depc=0x00000000
Can you help me tell about this error and how do fix it.
Thank,
By kolban
#26640 This exception means an attempt was made to read from an address space that is invalid. The program counter where the exception occurred was 0x4000deed and the address it tried to read was 0x0000000f. Without knowing your application, this is about all we can tell from the exception posted.
Neil
By Tinamore
#26642
kolban wrote:This exception means an attempt was made to read from an address space that is invalid. The program counter where the exception occurred was 0x4000deed and the address it tried to read was 0x0000000f. Without knowing your application, this is about all we can tell from the exception posted.
Neil
Thank for response.
I use [Ubuntu 14.04 LTS 64bit] and [pfalcon/esp-open-sdk] . I made exactly all the steps in https://github.com/Spritetm/esphttpd
When build the code run: make. I see a warning that appears in the last compile:
LD build/httpd.out
/home/sunny/esp-open-sdk/xtensa-lx106-elf/lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld:ldscript_memspecific.ld:1: warning: redeclaration of memory region `irom0_0_seg'
FW firmware
Is this error related to the Error: Fatal exception (28) ?
By trendchaster
#26655 Hello folks,
I am working on promiscuous mode. On cmd it shows following error shown below.What is issue with esp showing error as fatal exception.Kindly guide me.
Thanking you in advance
Management Packet (len=128) Sniffed on Channel 11
Step 1
Step 2
Step 3
Step 4
Fatal exception (9):
epc1=0x40100716, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000003, depc=0x00000000
ets Jan 8 2013,rst cause:1, boot mode:(3,7)
load 0x40100000, len 27536, room 16
tail 0
chksum 0x00
load 0x3ffe8000, len 1376, room 8
tail 8
chksum 0xb3
load 0x3ffe8560, len 5172, room 0
tail 4
chksum 0xdb
csum 0xdb
r
load ...
Hello esp-> -> Promiscuous mode setup ... done.
mode : sta(18:fe:34:a0:55:4f)
add if0
Step 1
Step 2
Step 3
Step 4
Data Packet (len=60) Sniffed on Channel 11
cnt: 1
rdaddr: 44:80:eb:ad:a3:52 tsaddr: c0:4a:00:e4:f3:4e bssid: 08:5b:0e:52:c9:f6 addr4: 01:00:3e:00:00:20
RSSI: -76
Step 1
Step 2
Step 3
