Sming - Open Source framework for high efficiency native ESP8266 development
By xlh1460
#20286
alonewolfx2 wrote:propably your sdk version different. sming working correctly on sdk 1.0.1 for now.
You are exactly right.
I had forgotten that last time I installed this, I needed to "downgrade" the SDK to version esp_iot_sdk_v1.0.1_b1_15_04_02 before I could get the examples to work.
What was strange was that before downgrading, I didn't have any issues with compilation, just with the examples functioning on the device.
I took a closer look at the SDK that was included with the UDK (version 2.0.5) and saw that although it appeared to be the same version as that I downloaded from Espressif, esp_iot_sdk_v1.0.1_15_04_24, a couple of the libraries, including the one causing the error were different. I don't know why the same SDK contains different files. At least I have it compiling OK now.
Code: Select allC:\Espressif>dir ESP8266_SDK\lib
 Volume in drive C is Acer
 Volume Serial Number is 1664-C64B
 Directory of C:\Espressif\ESP8266_SDK\lib
08/06/2015  03:33 PM    <DIR>          .
08/06/2015  03:33 PM    <DIR>          ..
21/05/2015  09:52 PM           205,224 libat.a
24/04/2015  04:45 PM            12,714 libjson.a
21/05/2015  09:52 PM           299,764 liblwip.a
21/05/2015  09:52 PM           119,530 libmain.a
21/05/2015  09:52 PM           186,122 libnet80211.a
24/04/2015  04:45 PM           145,068 libphy.a
24/04/2015  04:45 PM           180,144 libpp.a
24/04/2015  04:45 PM            93,184 libsmartconfig.a
24/04/2015  04:45 PM            10,640 libssc.a
24/04/2015  04:45 PM           164,570 libssl.a
24/04/2015  04:45 PM            16,212 libupgrade.a
21/05/2015  09:52 PM           124,580 libwpa.a
              12 File(s)      1,557,752 bytes
               2 Dir(s)  806,960,488,448 bytes free
C:\Espressif>dir esp_iot_sdk_v1.0.1_15_04_24\lib
 Directory of C:\Espressif\esp_iot_sdk_v1.0.1_15_04_24\lib
09/06/2015  09:23 PM    <DIR>          .
09/06/2015  09:23 PM    <DIR>          ..
24/04/2015  07:23 AM           205,224 libat.a
24/04/2015  05:45 AM            12,714 libjson.a
24/04/2015  05:45 AM           299,544 liblwip.a
24/04/2015  05:45 AM           109,456 libmain.a
24/04/2015  05:45 AM           185,970 libnet80211.a
24/04/2015  05:45 AM           145,068 libphy.a
24/04/2015  05:45 AM           180,144 libpp.a
24/04/2015  05:45 AM            93,184 libsmartconfig.a
24/04/2015  05:45 AM            10,640 libssc.a
24/04/2015  05:45 AM           164,570 libssl.a
24/04/2015  05:45 AM            16,212 libupgrade.a
24/04/2015  05:45 AM           124,464 libwpa.a
              12 File(s)      1,547,190 bytes
               2 Dir(s)  806,959,681,536 bytes free
By anakod
#20539
Sming can work on different version, but SDK 1.0.1 with Sming is completely tested and really stable for end users.
I'm trying to read a slave (an arduino, with the Slave Sender template) from an esp8266...
Did you try read real I2C devices? If it will work ok, you should check your pul-ups resistors. I think 2.4 KOm should be good but better test different values. Arduino have different voltage, so resistors should be bigger resistance.
By thehans
#20665 Hello, I'm unable to install sming on windows via chocolatey
Looks like a timeout for installing mingw-get? Is the url perhaps wrong or outdated, I don't really know how chocolatey works. Any help is appreciated.
Code: Select all2015-06-16 17:12:49,646 [INFO ] - ============================================================
2015-06-16 17:12:49,676 [INFO ] - Chocolatey v0.9.9.6
2015-06-16 17:12:49,886 [INFO ] - Chocolatey is unpacking required files for use. Overwriting? True
2015-06-16 17:13:36,769 [INFO ] - ============================================================
2015-06-16 17:13:36,799 [INFO ] - Chocolatey v0.9.9.6
2015-06-16 17:13:36,889 [INFO ] - Added kireevco - https://www.myget.org/F/kireevco-chocolatey/
2015-06-16 17:13:55,027 [INFO ] - ============================================================
2015-06-16 17:13:55,057 [INFO ] - Chocolatey v0.9.9.6
2015-06-16 17:13:55,127 [INFO ] - Installing the following packages:
2015-06-16 17:13:55,137 [INFO ] - sming
2015-06-16 17:13:55,137 [INFO ] - By installing you accept licenses for the packages.
2015-06-16 17:14:06,721 [INFO ] -
jre8 v8.0.45
2015-06-16 17:14:24,370 [INFO ] -  Java Runtime Environment 8.0.45 (32-bit) is already installed. Skipping downloa
2015-06-16 17:14:24,400 [INFO ] -  d and installation
2015-06-16 17:14:24,732 [INFO ] -  Downloading jre8 64 bit
2015-06-16 17:14:24,732 [INFO ] -    from 'http://javadl.sun.com/webapps/download/AutoDL?BundleId=106248'
2015-06-16 17:14:28,211 [INFO ] -  Installing jre8...
2015-06-16 17:14:44,688 [INFO ] -  jre8 has been installed.
2015-06-16 17:14:44,742 [INFO ] -  PATH environment variable does not have C:\Program Files\Java\jre1.8.0_45\bin in it. Adding...
2015-06-16 17:14:51,466 [INFO ] -  The install of jre8 was successful.
2015-06-16 17:14:51,476 [INFO ] -
eclipse-cpp v4.4.2
2015-06-16 17:14:52,314 [INFO ] -  Downloading eclipse-cpp 64 bit
2015-06-16 17:14:52,314 [INFO ] -    from 'http://ftp.halifax.rwth-aachen.de/eclipse//technology/epp/downloads/release/luna/SR2/eclipse-cpp-luna-SR2-win32-x86_64.zip'
2015-06-16 17:15:19,932 [INFO ] -  Extracting C:\Users\hans\AppData\Local\Temp\chocolatey\eclipse-cpp\eclipse-cppInstall.zip to C:\Program Files\Eclipse Foundation\4.4.2...
2015-06-16 17:15:19,949 [INFO ] -  Mode                LastWriteTime     Length Name
2015-06-16 17:15:19,953 [INFO ] -  ----                -------------     ------ ----
2015-06-16 17:15:19,957 [INFO ] -  d----        06/16/2015     17:15            4.4.2
2015-06-16 17:15:36,592 [INFO ] -  C:\Program Files\Eclipse Foundation\4.4.2
2015-06-16 17:15:36,612 [INFO ] -  Desktop Shortcut created pointing at 'C:\Program Files\Eclipse Foundation\4.4.2\eclipse\eclipse.exe'.
2015-06-16 17:15:36,852 [INFO ] -  'C:\Program Files\Eclipse Foundation\4.4.2\eclipse\eclipse.exe' has been pinned to the task bar on your desktop
2015-06-16 17:15:36,883 [INFO ] -  The install of eclipse-cpp was successful.
2015-06-16 17:15:36,903 [INFO ] -
esp8266-udk v2.0.1
2015-06-16 17:15:38,085 [INFO ] -  Downloading esp8266-udk 32 bit
2015-06-16 17:15:38,085 [INFO ] -    from 'http://programs74.ru/get.php?file=EspressifESP8266DevKit'
2015-06-16 17:15:49,240 [INFO ] -  Installing esp8266-udk...
2015-06-16 17:16:19,031 [INFO ] -  esp8266-udk has been installed.
2015-06-16 17:16:19,061 [INFO ] -  The install of esp8266-udk was successful.
2015-06-16 17:16:19,071 [INFO ] -
mingw v4.8.3.20141208
2015-06-16 17:16:19,349 [INFO ] -  Get-BinRoot is going to be deprecated by v1. Many packages no longer require it since the folders no longer have versions on them.
2015-06-16 17:16:19,841 [INFO ] -  Downloading mingw 64 bit
2015-06-16 17:16:19,841 [INFO ] -    from 'http://downloads.sourceforge.net/mingw-w64/x86_64-4.8.3-release-posix-seh-rt_v3-rev0.7z'
2015-06-16 17:17:07,853 [INFO ] -  Extracting C:\Users\hans\AppData\Local\Temp\chocolatey\mingw\mingwInstall.zip to C:\tools...
2015-06-16 17:17:07,870 [INFO ] -  Mode                LastWriteTime     Length Name
2015-06-16 17:17:07,874 [INFO ] -  ----                -------------     ------ ----
2015-06-16 17:17:07,877 [INFO ] -  d----        06/16/2015     17:17            tools
2015-06-16 17:18:22,403 [INFO ] -  C:\tools
2015-06-16 17:18:22,403 [INFO ] -  Adding 'C:\tools\mingw64' to the path and the current shell path
2015-06-16 17:18:22,423 [INFO ] -  PATH environment variable does not have C:\tools\mingw64\bin in it. Adding...
2015-06-16 17:18:22,513 [INFO ] -  The install of mingw was successful.
2015-06-16 17:18:22,533 [INFO ] -
mingw-get v1.0.3
2015-06-16 17:18:22,773 [INFO ] -  Get-BinRoot is going to be deprecated by v1. Many packages no longer require it since the folders no longer have versions on them.
2015-06-16 17:19:04,957 [ERROR] -  Exception calling "GetResponse" with "0" argument(s): "The operation has timed
2015-06-16 17:19:04,957 [ERROR] -  out"
2015-06-16 17:19:04,967 [ERROR] -  At C:\ProgramData\chocolatey\helpers\functions\Get-WebHeaders.ps1:77 char:37
2015-06-16 17:19:04,967 [ERROR] -  +     $response = $request.GetResponse <<<< ();
2015-06-16 17:19:04,977 [ERROR] -      + CategoryInfo          : NotSpecified: (:) [], ParentContainsErrorRecordE
2015-06-16 17:19:04,997 [ERROR] - The install of mingw-get was NOT successful.
2015-06-16 17:19:04,997 [ERROR] -     xception
2015-06-16 17:19:04,997 [ERROR] - Error while running 'C:\ProgramData\chocolatey\lib\mingw-get\tools\chocolateyInstall.ps1'.
 See log for details.
2015-06-16 17:19:05,007 [ERROR] -      + FullyQualifiedErrorId : DotNetMethodException
2015-06-16 17:19:07,056 [INFO ] -
sming.core v0.0.4
2015-06-16 17:19:07,417 [INFO ] -  Get-BinRoot is going to be deprecated by v1. Many packages no longer require it since the folders no longer have versions on them.
2015-06-16 17:19:08,279 [INFO ] -  Downloading sming 32 bit
2015-06-16 17:19:08,279 [INFO ] -    from 'https://github.com/anakod/Sming/archive/master.zip'
2015-06-16 17:19:10,973 [INFO ] -  Extracting C:\Users\hans\AppData\Local\Temp\chocolatey\sming\smingInstall.zip to C:\tools\sming...
2015-06-16 17:19:10,983 [INFO ] -  Mode                LastWriteTime     Length Name
2015-06-16 17:19:10,993 [INFO ] -  ----                -------------     ------ ----
2015-06-16 17:19:10,993 [INFO ] -  d----        06/16/2015     17:19            sming
2015-06-16 17:19:14,482 [INFO ] -  C:\tools\sming
2015-06-16 17:19:15,935 [INFO ] -  The install of sming.core was successful.
2015-06-16 17:19:15,945 [INFO ] -
bc v1.06
2015-06-16 17:19:16,386 [INFO ] -  Get-BinRoot is going to be deprecated by v1. Many packages no longer require it since the folders no longer have versions on them.
2015-06-16 17:19:16,820 [INFO ] -  Downloading bc 32 bit
2015-06-16 17:19:16,820 [INFO ] -    from 'http://downloads.sourceforge.net/project/gnuwin32/bc/1.06-2/bc-1.06-2.exe'
2015-06-16 17:19:20,396 [INFO ] -  Installing bc...
2015-06-16 17:19:21,144 [INFO ] -  bc has been installed.
2015-06-16 17:19:21,184 [INFO ] -  The install of bc was successful.
2015-06-16 17:19:21,204 [INFO ] -
srecord v1.64
2015-06-16 17:19:21,584 [INFO ] -  Get-BinRoot is going to be deprecated by v1. Many packages no longer require it since the folders no longer have versions on them.
2015-06-16 17:19:22,037 [INFO ] -  Downloading srecord 32 bit
2015-06-16 17:19:22,037 [INFO ] -    from 'http://downloads.sourceforge.net/project/srecord/srecord-win32/1.64/srecord-1.64-win32.zip'
2015-06-16 17:19:27,087 [INFO ] -  Extracting C:\Users\hans\AppData\Local\Temp\chocolatey\srecord\srecordInstall.zip to C:\tools\mingw64\bin...
2015-06-16 17:19:27,500 [INFO ] -  C:\tools\mingw64\bin
2015-06-16 17:19:27,540 [INFO ] -  The install of srecord was successful.
2015-06-16 17:19:27,550 [INFO ] -
spiffy v1.0.3.05112015
2015-06-16 17:19:27,920 [INFO ] -  Get-BinRoot is going to be deprecated by v1. Many packages no longer require it since the folders no longer have versions on them.
2015-06-16 17:19:28,480 [INFO ] -  Downloading spiffy 32 bit
2015-06-16 17:19:28,480 [INFO ] -    from 'https://bintray.com/artifact/download/kireevco/generic/spiffy-1.0.3-win32-x86_64.zip'
2015-06-16 17:19:30,857 [INFO ] -  Extracting C:\Users\hans\AppData\Local\Temp\chocolatey\spiffy\spiffyInstall.zip to C:\tools\mingw64\bin...
2015-06-16 17:19:30,987 [INFO ] -  C:\tools\mingw64\bin
2015-06-16 17:19:31,027 [INFO ] -  The install of spiffy was successful.
2015-06-16 17:19:31,037 [INFO ] -
sming v1.0.5.20150507
2015-06-16 17:19:31,419 [INFO ] -  Get-BinRoot is going to be deprecated by v1. Many packages no longer require it since the folders no longer have versions on them.
2015-06-16 17:19:31,469 [INFO ] -  PATH environment variable does not have C:\tools\mingw64\bin;C:\tools\mingw64\msys\1.0\bin in it. Adding...
2015-06-16 17:19:31,579 [INFO ] -  Installing / updading required mingw packages
2015-06-16 17:19:31,609 [ERROR] -  Exception calling "Start" with "1" argument(s): "The system cannot find the fil
2015-06-16 17:19:31,609 [ERROR] -  e specified"
2015-06-16 17:19:31,609 [ERROR] -  At C:\ProgramData\chocolatey\helpers\functions\Start-ChocolateyProcessAsAdmin.p
2015-06-16 17:19:31,619 [ERROR] -  s1:76 char:43
2015-06-16 17:19:31,619 [ERROR] -  +   $s = [System.Diagnostics.Process]::Start <<<< ($psi)
2015-06-16 17:19:31,619 [ERROR] -      + CategoryInfo          : NotSpecified: (:) [], MethodInvocationException
2015-06-16 17:19:31,629 [ERROR] -      + FullyQualifiedErrorId : DotNetMethodException
2015-06-16 17:19:31,629 [ERROR] -  You cannot call a method on a null-valued expression.
2015-06-16 17:19:31,629 [ERROR] -  At C:\ProgramData\chocolatey\helpers\functions\Start-ChocolateyProcessAsAdmin.p
2015-06-16 17:19:31,639 [ERROR] -  s1:81 char:29
2015-06-16 17:19:31,639 [ERROR] -  +   $s.StandardError.ReadToEnd <<<< () | Out-File $errorFile
2015-06-16 17:19:31,639 [ERROR] -      + CategoryInfo          : InvalidOperation: (ReadToEnd:String) [], Runtime
2015-06-16 17:19:31,649 [ERROR] -     Exception
2015-06-16 17:19:31,649 [ERROR] -      + FullyQualifiedErrorId : InvokeMethodOnNull
2015-06-16 17:19:31,649 [ERROR] -  You cannot call a method on a null-valued expression.
2015-06-16 17:19:31,659 [ERROR] -  At C:\ProgramData\chocolatey\helpers\functions\Start-ChocolateyProcessAsAdmin.p
2015-06-16 17:19:31,659 [ERROR] -  s1:82 char:17
2015-06-16 17:19:31,669 [ERROR] -  +   $s.WaitForExit <<<< ()
2015-06-16 17:19:31,669 [ERROR] -      + CategoryInfo          : InvalidOperation: (WaitForExit:String) [], Runti
2015-06-16 17:19:31,679 [ERROR] -     meException
2015-06-16 17:19:31,679 [ERROR] -      + FullyQualifiedErrorId : InvokeMethodOnNull
2015-06-16 17:19:31,679 [ERROR] -  Get-Content : Cannot find path 'C:\Users\hans\AppData\Local\Temp\chocolatey\-er
2015-06-16 17:19:31,689 [ERROR] -  ror.stream' because it does not exist.
2015-06-16 17:19:31,689 [ERROR] -  At C:\ProgramData\chocolatey\helpers\functions\Start-ChocolateyProcessAsAdmin.p
2015-06-16 17:19:31,689 [ERROR] - The install of sming was NOT successful.
2015-06-16 17:19:31,689 [ERROR] -  s1:88 char:32
2015-06-16 17:19:31,699 [ERROR] - Error while running 'C:\ProgramData\chocolatey\lib\sming\tools\chocolateyInstall.ps1'.
2015-06-16 17:19:31,699 [ERROR] -  +       $innerError = Get-Content <<<<  $errorFile | Out-String
2015-06-16 17:19:31,709 [ERROR] -      + CategoryInfo          : ObjectNotFound: (C:\Users\hans\A...y\-error.stre
2015-06-16 17:19:31,709 [ERROR] -     am:String) [Get-Content], ItemNotFoundException
2015-06-16 17:19:31,709 [ERROR] -      + FullyQualifiedErrorId : PathNotFound,Microsoft.PowerShell.Commands.GetCo
2015-06-16 17:19:31,719 [ERROR] -     ntentCommand
2015-06-16 17:19:31,719 [ERROR] -  [ERROR] Running C:\tools\mingw64\bin\mingw-get.exe with install mingw32-base --
2015-06-16 17:19:31,719 [ERROR] -  reinstall --recursive was not successful. Exit code was '' Error Message: .
2015-06-16 17:19:31,729 [ERROR] -  At C:\ProgramData\chocolatey\helpers\functions\Start-ChocolateyProcessAsAdmin.p
2015-06-16 17:19:31,729 [ERROR] -  s1:92 char:10
2015-06-16 17:19:31,729 [ERROR] -  +     throw <<<<  $errorMessage
2015-06-16 17:19:31,739 [ERROR] -      + CategoryInfo          : OperationStopped: ([ERROR] Running...rror Messag
2015-06-16 17:19:31,739 [ERROR] -     e: .:String) [], RuntimeException
2015-06-16 17:19:31,739 [ERROR] -      + FullyQualifiedErrorId : [ERROR] Running C:\tools\mingw64\bin\mingw-get.e
2015-06-16 17:19:31,739 [ERROR] -     xe with install mingw32-base --reinstall --recursive was not successful. E
2015-06-16 17:19:31,749 [ERROR] -    xit code was '' Error Message: .
2015-06-16 17:19:33,719 [WARN ] -
Chocolatey installed 8/10 package(s). 2 package(s) failed.
 See the log for details (C:\ProgramData\chocolatey\logs\chocolatey.log).
2015-06-16 17:19:33,729 [ERROR] - Failures:
2015-06-16 17:19:33,729 [ERROR] -  - mingw-get
2015-06-16 17:19:33,729 [ERROR] -  - sming
