RichardS wrote:danbicks wrote:Richard,
See the following post: http://www.ebay.co.uk/itm/Rev2-ESP-03-C ... 35ee530998
Very similar to your solution, already out there although this one communicates through serial without the flexibility of programming the ESP through the IDE.
Dans
Well that sucks, misses the point...thats why we are chatting it up here before the final release. Misses also the FCC and the power supply issues being fixed, as there is no current left for the person to experiment with!!!! The regulation of the power is very key with ESP8266 devices, most people under power them and have reset issues.
Richard.
Additional current should be supplied by external circuitry, never a good idea to power external devices of CPU regulator source. In terms of FCC, a screened can does not always guarantee harmonic levels fall within compliance, PCB design and track work are a key factor here, one should use through hole via's to a solid ground plane around any devices that generate RF. This come's from many years experience designing FM broadcast transmitter solutions.
I think it would be a good idea for you to publish your schematic so we can all input in to the design stage and see if any further improvements can be made.
Nice board-work by the way, good job so far.
Dans
