- Thu Dec 29, 2016 6:17 pm
#60117
Thanks for the input, but what "OS Utility" are you referring to here?
Also "try flashing several times" seems like odd advice. We aren't writing on sandstone with a sharp stick or something.
In any case I tried a few repeated flash operations using the ESPBasicFlasher but still no go.
The OS utility or Tool that I am referring to is just the ESP flasher utility.
You are right... "not sandstone" but it took a couple of time to get the module flashed and working after I did the "format" button (the Format option does not seem to work when I try it and it did seem to make my module not work)
Sorry you are having so much dificulty. I have successfully flashed around a dozen different modules and they all seem to work. esp8266-01, nodemcu, Sonoff
Do you ever see the blue LED on your module blinking rapidly during the flash routine??
In order to get the module into the flash mode you might try holding down the reset button then press the flash button then release the reset then release the flash button last, then click the "Firmware Flash" button in the utility. After a few seconds you should see the LED blinking rapidly until the flash is complete. Do you ever get that far??
I would suggest you try a different module and see if you have success there. When you get one working you will have more confidence in how it is supposed to work and what to expect.
good luck
dwight
