Place to put your Basic demos and examples
By GengusKahn
#37836 Hi there, another Self refreshing gauge fed from thingspeak....HTML.....
Code: Select all <html lang="en">
 <head>
   <meta charset="utf-8">
   <title>ESP8266-Environment-Monitor</title>
 </head>
<font color="#000000"><body bgcolor="#a0dFfe"><meta name="viewport" content="width=device-width, initial-scale=1.0, user-scalable=yes">
   <h2>Environmental Sensor Readings</h2>
   <h2>Using an ESP8266 with 2 DHT11<BR>& 1 DS18B20 Environment Sensors<BR><BR> ♂♀♪♫☼►</h2>
<BR><BR><a href="http://esp8266.com/">Find out how this is done Visit ESP8266.COM Support Forum</a><BR><BR><BR>
   <script src="http://ajax.googleapis.com/ajax/libs/jquery/1.5/jquery.min.js"></script>
<div style="float:left;">
<div id="ESPS001" style="float:left;"><a href="https://freeboard.io/board/ISfNF7">Freeboard IO Dashboard</a><BR><a href="http://82.5.78.180:92/jsread">GET JSON Frame</a><BR><a href="http://82.5.78.180:92/diag">Device Information Page</a><BR>Readings from<BR>ESP8266 Sensors </div>
    <div id="container">
  <style type="text/css">
  #container { height: 10%; width: 10%; display: table; }
  #gauge_div { width: 100px; margin: 0 auto; }
ESPS001, th , td {
    border: 1px solid cyan;
    border-collapse: collapse;
    padding: 5px;
</style>
Google Gauge Via Thingspeak JSON Frame
      <div id="inner">
        <div id="gauge_div"></div>
      </div>
    </div>
</div>
 <script>
$.ajax({
    // get the data from ESP8266 sensors via CORS Enabled JSON Frame
    // CORS explaination found here...
    //   https://developer.mozilla.org/en-US/docs/Web/HTTP/Access_control_CORS
    type: "GET",
    url: "http://82.5.78.180:92/jsread",
    async: false,
    beforeSend: function(x) {
     if(x && x.overrideMimeType) {
      x.overrideMimeType("application/j-son;charset=UTF-8");
// Now parse the JSON frame for valid "Key:Value" pairs, as many as you have formed in your sketch the list does not have a size
// Repeated keys will be omitted...
 dataType: "json",
 success: function(data){
     var items = [];
     $.each(data, function(key, val) {
       items.push("<tr><td> "+ key +" </td><td> " + val + " </td></tr> ");
     $('.my-new-list').remove();
     $('<ul/>', {
       'class': 'my-new-list',
       html: items.join('')
// Now place the parsed data into the div for display, or do something with the data in the ESP Sketch...
     }).appendTo('#ESPS001');
   </script>
  <script type='text/javascript' src='https://ajax.googleapis.com/ajax/libs/jquery/1.9.1/jquery.min.js'></script>
<script type='text/javascript' src='https://www.google.com/jsapi'></script>
<script type='text/javascript'>
  // set your channel id here
  var channel_id = 75183;
  // set your channel's read api key here if necessary
  var api_key = '';
  // maximum value for the gauge
  var max_gauge_value = 50;
  // name of the gauge
  var gauge_name = 'DS18-Temp';
  // global variables
  var chart, charts, data;
  // load the google gauge visualization
  google.load('visualization', '1', {packages:['gauge']});
  google.setOnLoadCallback(initChart);
  // display the data
  function displayData(point) {
    data.setValue(0, 0, gauge_name);
    data.setValue(0, 1, point);
    chart.draw(data, options);
  // load the data
  function loadData() {
    // variable for the data point
    var p;
    // get the data from thingspeak in the form of a rather large JSON Frame
    // containing lots of useful data interaction for the ESP8266 sketch
    $.getJSON('https://api.thingspeak.com/channels/' + channel_id + '/feed/last.json?api_key=' + api_key, function(data) {
      // get the data point from within the Thingspeak JSON Frame
      p = data.field5;
      // if there is a data point display it
      if (p) {
       // p = Math.round((p / max_gauge_value) * 100);
        displayData(p);
  // initialize the chart & Request data after the Sensor data list is populated
  function initChart() {
    data = new google.visualization.DataTable();
    data.addColumn('string', 'Label');
    data.addColumn('number', 'Value');
    data.addRows(1);
    chart = new google.visualization.Gauge(document.getElementById('gauge_div'));
    options = {width: 300, height: 300, min: 0, max: 50, redFrom: 32, redTo: 50, yellowFrom:0, yellowTo: 17, minorTicks: 10};
    loadData();
    // load new data every 15 seconds
    setInterval('loadData()', 15000);
    // Thingspeak Matlab Frame, this is directly pasted from the html provided by the Thingspeak Page....
</script>
<BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR>
Thingspeak Data Visualisation via Matlab Chart
<div style="float:none;"><iframe width="450" height="375" style="border: 1px solid #cccccc;" src="http://api.thingspeak.com/apps/matlab_visualizations/41029" ></iframe>
<BR>environmental.monitor.log@gmail.com<BR><FONT SIZE=-2>ESP8266 With Various Sensors<BR><FONT SIZE=-2>Compiled Using ver. 2.0.0-rc2, built December, 2015<BR></div>
</body>
</html>
By Sazkat2
#38331 Hi there,
Could you offer me some advice please???!! I am very new to all this and am struggling to find out what code I need to get a gauge on my website to show live data. I have been searching the Internet for a week now and just don't know where to start with my very limited skills. I saw this post and thought is would be brilliant if I could figure out how to change the code to show the data I need!
What I am trying to do is get the value displayed at this webpage http://www.irf.se/maggraphs/preliminary ... 15_minutes and show it in a gauge on my website. The value on the webpage changes so the gauge will need to auto refresh.
Thanks in advance for any help you can give me
Sarah
By Sazkat2
#38340
GengusKahn wrote:Hi there, another Self refreshing gauge fed from thingspeak....HTML.....
 <head>
 </head>
ESPS001, th , td {
    padding: 5px;
</style>
      <div id="inner">
      </div>
    </div>
</div>
 <script>
$.ajax({
    type: "GET",
    async: false,
 dataType: "json",
     var items = [];
     $('<ul/>', {
   </script>
  var api_key = '';
  // global variables
  // display the data
  // load the data
    var p;
      p = data.field5;
      if (p) {
        displayData(p);
    data.addRows(1);
    loadData();
</script>
</body>
</html>
Hi there
Sarah
By Carlitos007
#80290
Mmiscool wrote:Nice.
So here is a single meter that will display the analog input pin and refresh ever 5 seconds.
Hi!
I'm new to both gauges, and Esp8622.
I have read tons of threads but most related to Arduinos, this is the only one on the ESP8622!
can you load the Final code or complete sketch. I'm confused between Jquery, Ajax,and plain HTML.
I figure if I have a guide of a working model with the ESP8622 and Dynamic gauges would be easier for me to understand.
From what I understand this gauges are being loaded with the HTML and updated without the need of JS or CSS files?
