wifi.setmode(wifi.STATION)
wifi.sta.config("ssid----","password")
tmr.alarm(0, 1000, 1, function(QQ)
print("Try Connecting:")
ip, nm, gw=wifi.sta.getip()
if ip ~= nil then
print("\nIP Info: \nIP Address: ",ip,"\n Netmask: ",nm,"\n Gateway: ",gw)
tmr.stop(0)
end)
rfctr=0
adc_id = 0
adc_value = 512
k1=0.11
p00='P'
apc0='11111'
ppm0='1770'
cdeg0='25.1'
kta0='0.01'
lo0='12'
hi0='20'
prb='01.0'
ph='7.0'
sbuf=('D=dump Z=calibrate= z [table 1-5] [slot0-9] ppmcal ppmcnt\r\n'
..'============================== EEPROM DUMP ======================\r\n'
..'000> 00001,00032 00342,65535 00700,66535 01000,34770 01400,65535\r\n020>\r\n040>\r\n060>\r\n080>\r\n100>\r\n120>\r\n140>\r\n160>\r\n180>\r\n')
--..'020>\r\n') -- 01840,45350 02000,48550 02450,66535 02800,65535 03260,54350\r\n'
--..'040>\r\n') -- 00001,00032 00342,65535 00700,66536 01000,34770 01400,65535\r\n'
--..'060>\r\n' --- 00001,00032 00342,65535 00700,66536 01000,34770 01400,65535\r\n')
--..'000>\r\n' -- 00001,00032 00342,65535 00700,66536 01000,34770 01400,65535\r\n')
--..'000>\r\n') -- 00001,00032 00342,65535 00700,66536 01000,34770 01400,65535\r\n')
--..'000>\r\n') -- 00001,00032 00342,65535 00700,66536 01000,34770 01400,65535\r\n')--]]
--EOpn = "http://i.imgur.com/kzt3tO8.png"
--EClo = "http://i.imgur.com/KS1dPa7.png"
---s_img = EOpn
Eopn=0
B_Opn = "http://i.imgur.com/kzt3tO8.png"
B_Clo = "http://i.imgur.com/KS1dPa7.png"
bgc="Cyan"
s_img = B_Opn
-- simple uart input appears to work
uart.setup(0,9600,8,0,1)
--uart.on("data",40,function(data) print("Rcv uart: ",data) end,0)
--uart.on("data","\n\r",function(data) print("Rcv uart: ",data) end,0)
--uart.setup(0,9600,8,0,1)
srv = net.createServer(net.TCP, 30)
srv:listen(80,function(C)
C:on("receive", function(C, payload)
function esp_update()
--print("--PL--",payload)
m_do=string.sub(payload,postparse[2]+1,#payload)
x=string.find(m_do,"&m_do=")
if x ~= nil then
cmd=string.sub(m_do,x+6,#m_do)
m_do=string.sub(m_do,1,x-1)
cmd=string.sub(m_do,1,#m_do)
m_do=nil
cmd=string.gsub(cmd,"+","") -- remove lead/trail +
-- print("m_do-2 ",m_do," cmd "..cmd)
if cmd ~= nil then
uart.write(0,cmd.."\n\r") -- send to PIC
-- print("-->uart-->pic=|"..cmd.."\n\r")
if m_do == "RD_ADC" then
adc_value = adc.read(adc_id)
if adc_value > 1023 then
adc_value = 1023
elseif adc_value < 0 then
adc_value = 0
if m_do == "BLINK" then
if Eopn==0 then
s_img =B_Clo
Eopn=1
bgc="Yellow"
s_img =B_Opn
Eopn=0
bgc="Cyan"
if m_do == "TEMP_DN" then
apc0 = apc0 + 100
cdeg0=round2((cdeg0-1),1)
if m_do == "TEMP_UP" then
apc0 = apc0 - 100
cdeg0=round2((cdeg0+1),1)
postparse={string.find(payload,"m_do=")}
if postparse[2]~=nil then esp_update()end
--C:send('HTTP/1.1 200 OK\n\n')
fdeg0 = round2((cdeg0*1.8) +32,1)
ppm1=round2(ppm0/(((cdeg0-25)*.021)+1),1)
ppm2=round2((ppm0*46.5)/(cdeg0+21.5),1 )
pha=25-cdeg0
if pha < 0 then
pha = round2((ph + (pha*.002)),2)
pha = round2((ph + (pha*.004)),2)
rfh='15'
C:send('<!DOCTYPE HTML>\n<html lang="en-US">\n<head><meta http-equiv="refresh" content="'..rfh..'" ></head>\n')
C:send('<script type = "text/javascript">\nvar timeInSecs;\nvar ticker;')
C:send('function startTimer(secs){ timeInSecs = parseInt(secs)-1; ticker = setInterval("tick()",1000); }')
C:send('function tick() { var secs = timeInSecs; if (secs>0) {timeInSecs--;} else {clearInterval(ticker); startTimer('..rfh..');}')
C:send('document.getElementById("countdown").innerHTML = secs;} startTimer('..rfh..'); </script>')
C:send('<body><div><table bgcolor="Lawngreen" border="1" cellpadding="5"><th><h1>ESP8266 Blinker Thing!</h1></th><td>'
..'<IMG SRC="'..s_img..'" LEFT="1" WIDTH="120" HEIGHT="60" BORDER="1"></td><th id="countdown">'..rfh..'</th></table><div><br>')
--C:send('<textarea name="cmds" cols="70" rows="14">'..sbuf..'</textarea></div><br>')
C:send('<textarea name="cmds" cols="70" rows="6">'..sbuf..'</textarea></div><br>')
C:send('<div><table bgcolor="'..bgc..'" border="1" cellpadding="5">')
C:send('<tr><th>Sensor</th><th>TempC</th><th>TempF</th><th>PPMcntr</th><th>PPM__</th><th>Adj__1</th><th>Adj__2</th></tr>')
C:send('<tr><td>DS18B20'..p00..'</td><td>'..cdeg0..'</td><td>'..fdeg0..'</td><td>'..apc0..'</td><td>'..ppm0..'</td><td>'..ppm1..'</td><td>'..ppm2..'</td></tr>')
C:send('<tr><th>Probe-K</th><th>Pool-PH</th><th>PH-Adj</th><th>ADC Value</th></tr>')
C:send('<tr><td>'..prb..'</td><td>'..ph..'</td><td>'..pha..'</td><td bgcolor="Red">'..adc_value..'</td></tr>')
C:send('</table></div><br><form action="" method="POST">\n')
C:send('<input type="submit" name="m_do" value="BLINK" style="padding:5px;10px;">')
C:send('<input type="submit" name="m_do" value="RD_ADC" style="padding:5px;10px;">')
C:send('<input type="submit" name="m_do" value="TEMP_DN" style="padding:5px;10px;">')
C:send('<input type="submit" name="m_do" value="TEMP_UP" style="padding:5px;10px;"><br>')
C:send('"CMD:"<input type="text" name="m_do" value="" maxlength="100" style="padding:5px;10px;">')
C:send('<input type="submit" value="Submit"></form>\n<br></body></html>\n')
C:on("sent", function(C) C:close() end)
end)
rfctr=(rfctr+1)
rfc=math.floor((rfctr/2)+0.5) -- seems to double count so /2 and round
if (rfc % 2)==0 then
bgc="Cyan" --even
bgc="Yellow" --odd
end)
function round2(num, idp)
return tonumber(string.format("%." .. (idp or 0) .. "f", num))
function si(sIN)
buffer=sIN
-- print("\n\rbuf--",buffer)
if string.find(sIN,"co") then
if string.find(sIN,"bo") then
cx=(string.find(sIN,"co"))+2
cdeg0 = string.sub(sIN,cx,cx+3)
if string.find(sIN,"ao") then
cx=(string.find(sIN,"bo"))+2
ppm0=string.sub(sIN,cx,cx+3)
if string.find(sIN,"xo") then
cx=(string.find(sIN,"ao"))+2
apc0 = string.sub(sIN,cx,cx+4)
function cbuf()
if #sbuf + #sIN > 200 then
sbuf = sIN
sbuf = sbuf..sIN
function all_trm(s)
return s:match( "^%s*(.-)%s*$" )
function all_trim(s)
return s:match"^%s*(.*)":match"(.-)%s*$"
It certanly sounds possible.
http://esp8266basic.com
A BASIC interpreter for your ESP
Working now on Autodrop3d. A 3d printer with automatic part ejection system. https://autodrop3d.com
Then send this data over serial port to the esp and update several vars in the esp which will get sent on the next web page refresh to update the web page and display the new updated values. Commands can be sent from web page to PIC
to display additional data...
Using NodeMCU I run out of memory. Have some ESP-13 ordered which are susposed to have more ram...
NodeMCU also uses serial port for logging and does not have any way to stop it which causes problems...
Will your basic include string vars A$, b$ etc and String functions Len, mid$ ,instr, left$, right$ etc. ?
this would be a big +,,,, Is there any reason you use Let A = x verses A=x ????
Could you pls implement the method which will print/load vars with allocated IP/s.
Thanks.
