GPIO3 is the RX-input but if you don't use serial-input, this pin can be used without problems.
something like this:
Explore... Chat... Share...
#include <DHT.h> // adafruit library
DHT dht(5, DHT21); // 5 is GPIO5, DHT21 you may want change at DHT11 or DHT22
dht.begin(); // in setup()
if ( Param0 == F("dtemp"))
SetMeThatVar(Param1, String(dht.readTemperature())); // if you want temperature in celcius scale
// SetMeThatVar(Param1, String(dht.readTemperature(true))); // if you want temperature in fahrenheit scale
return;
if ( Param0 == F("dhum"))
SetMeThatVar(Param1, String(dht.readHumidity()));
return;
if ( Param0 == F("dheatindex"))
SetMeThatVar(Param1, String(dht.computeHeatIndex(t, h, false))); // if you want heat index in celcius scale
// SetMeThatVar(Param1, String(dht.computeHeatIndex(t, h))); // if you want heat index in fahrenheit scale
return;
if ( Param0 == "temp" | Param0 == "ti")
