Report Bugs Here
By leclou
#95041 here my code
Template for static IP,MQTT &DeepSleep
Read out a DHT11
https://arduinodiy.wordpress.com/2020/0 ... rt-3-mqtt/
long SLEEPTIME = 60e6; //1min
const char* WLAN_SSID = "xxx";
const char* WLAN_PASSWD = "xxx";
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <PubSubClient.h>
#include <Wire.h>
#include "DFRobot_SHT20.h"
// We make a structure to store connection information
// The ESP8266 RTC memory is arranged into blocks of 4 bytes. The access methods read and write 4 bytes at a time,
// so the RTC data structure should be padded to a 4-byte multiple.
struct {
uint32_t crc32; // 4 bytes
uint8_t channel; // 1 byte, 5 in total
uint8_t ap_mac[6];// 6 bytes, 11 in total
uint8_t padding; // 1 byte, 12 in total
} rtcData;
IPAddress ip(192, 168, 0, 202); // pick your own IP outside the DHCP range of your router
IPAddress gateway(192, 168, 0, 1); //watch out, these are comma's not dots
IPAddress subnet(255, 255, 234, 129);
IPAddress dns(207, 164, 0, 1);
//---------voor pubsub
WiFiClient espClient;
PubSubClient client(espClient);
//---------Other------
String naam = (__FILE__); // filenaam
//unsigned int batt;
ADC_MODE(ADC_VCC); // vcc uitlezen.
//--------DHT11------
//float humid_hok;
//float temp_hok;
/*#include <DHT.h>
#define DHTTYPE DHT11
#define DHTPIN 2 // D4
DHT dht(DHTPIN, DHTTYPE, 11);*/ //
DFRobot_SHT20 sht20;
int pinOut = 10;
float humd;
float temp;
float batt;
pinMode(pinOut, OUTPUT);
// we disable WiFi, coming from DeepSleep, as we do not need it right away
WiFi.mode( WIFI_OFF );
WiFi.forceSleepBegin();
delay( 1 );
Serial.println("wifi uit");
// Try to read WiFi settings from RTC memory
bool rtcValid = false;
if ( ESP.rtcUserMemoryRead( 0, (uint32_t*)&rtcData, sizeof( rtcData ) ) ) {
// Calculate the CRC of what we just read from RTC memory, but skip the first 4 bytes as that's the checksum itself.
uint32_t crc = calculateCRC32( ((uint8_t*)&rtcData) + 4, sizeof( rtcData ) - 4 );
if ( crc == rtcData.crc32 ) {
rtcValid = true;
//now do stuff
Serial.println("do stuff");
//strip naam
//strip path van filenaam
byte p1 = naam.lastIndexOf('\\');
byte p2 = naam.lastIndexOf('.');
naam = naam.substring(p1 + 1, p2);
batt = ESP.getVcc();
Serial.println(batt/1023.0F);
batt = batt/1023.0F;
Serial.print("Sketch name ");
Serial.println(naam);
Serial.print("Battery Voltage ");
Serial.println(batt);
digitalWrite(pinOut, HIGH);
delay(50);
sht20.initSHT20(); // Init SHT20 Sensor
delay(100);
sht20.checkSHT20(); // Check SHT20 Sensor
humd = sht20.readHumidity(); // Read Humidity
temp = sht20.readTemperature();
digitalWrite(pinOut, LOW);
// Read Temperature
Serial.print("Time:");
Serial.print(millis());
Serial.print(" Temperature:");
Serial.print(temp, 1);
Serial.print("C");
Serial.print(" Humidity:");
Serial.print(humd, 1);
Serial.print("%");
// Start connection WiFi
//Switch Radio back On
WiFi.forceSleepWake();
delay( 1 );
// Disable the WiFi persistence. The ESP8266 will not load and save WiFi settings unnecessarily in the flash memory.
WiFi.persistent( false );
Serial.println("Start WiFi");
// Bring up the WiFi connection
WiFi.mode( WIFI_STA );
WiFi.config( ip, dns, gateway, subnet );
//-----------Now we replace the normally used "WiFi.begin();" with a precedure using connection data stored by us
if ( rtcValid ) {
// The RTC data was good, make a quick connection
WiFi.begin( WLAN_SSID, WLAN_PASSWD, rtcData.channel, rtcData.ap_mac, true );
else {
// The RTC data was not valid, so make a regular connection
WiFi.begin( WLAN_SSID, WLAN_PASSWD );
//WiFi.begin( WLAN_SSID, WLAN_PASSWD );
//------now wait for connection
int retries = 0;
int wifiStatus = WiFi.status();
while ( wifiStatus != WL_CONNECTED ) {
retries++;
if ( retries == 100 ) {
// Quick connect is not working, reset WiFi and try regular connection
WiFi.disconnect();
delay( 10 );
delay( 10 );
delay( 10 );
if ( retries == 600 ) {
// Giving up after 30 seconds and going back to sleep
WiFi.disconnect( true );
delay( 1 );
ESP.deepSleep( SLEEPTIME, WAKE_RF_DISABLED );
return; // Not expecting this to be called, the previous call will never return.
delay( 50 );
Serial.println(" WiFi connected");
// Write current connection info back to RTC
rtcData.channel = WiFi.channel();
memcpy( rtcData.ap_mac, WiFi.BSSID(), 6 ); // Copy 6 bytes of BSSID (AP's MAC address)
rtcData.crc32 = calculateCRC32( ((uint8_t*)&rtcData) + 4, sizeof( rtcData ) - 4 );
ESP.rtcUserMemoryWrite( 0, (uint32_t*)&rtcData, sizeof( rtcData ) );
//---------As we are connected to WiFi, begin MQTT connection
client.setServer("192.168.0.101", 1883); //your MQTT server's IP.Mind you, these are separated by dots again
//client.setCallback(callback);
//-------Here is where you send data
Serial.println("Start Sending data");
sendMQTTmessage();
/* Close WiFi connection */
//client.stop();
//----and go to back to sleep
Serial.println("Go back to sleep");
delay( 1 );
// WAKE_RF_DISABLED to keep the WiFi radio disabled when we wake up
void sendMQTTmessage()
if (!client.connected()) {
reconnect();
static char hygroBatt[7];
dtostrf(batt, 6, 2, hygroBatt);
static char hygroTemp[7];
dtostrf(temp, 6, 2, hygroTemp);
static char hygroHumi[7];
dtostrf(humd, 6, 2, hygroHumi);
//client.publish("home/sleep/tele/naam", naam.c_str(), false);
//client.publish("home/sleep/batt3", String(batt / 1023.0F).c_str(), false);
// client.publish("home/main/esp3/temp3",String(sht20.readTemperature()).c_str(),false);//alternatively: read the sensor when wifi off
// client.publish("home/main/esp3/humidity3",String(sht20.readHumidity()).c_str(),false);
client.publish("home/main/esp2/temp2", hygroTemp);
client.publish("home/main/esp2/humidity2", hygroHumi);
client.publish("home/sleep/batt2",hygroBatt);
/* Close MQTT client cleanly */
client.disconnect();
void reconnect() {
while (!client.connected())
String ClientId = "ESP8266";
ClientId += String(random(0xffff), HEX);
if (client.connect(ClientId.c_str()))
//if your MQTT server is protected with a password, use the next line instead of the revious
//if (client.connect(ClientId.c_str()),mqtt_user,mqtt_password))
Serial.print("Connected");
client.publish("home/hok/stat/connection", "OK");
} else {
Serial.print("failed, rc= ");
Serial.print(client.state());
delay(1000);
// the CRC routine
uint32_t calculateCRC32( const uint8_t *data, size_t length ) {
uint32_t crc = 0xffffffff;
while ( length-- ) {
uint8_t c = *data++;
for ( uint32_t i = 0x80; i > 0; i >>= 1 ) {
bool bit = crc & 0x80000000;
if ( c & i ) {
bit = !bit;
crc <<= 1;
if ( bit ) {
crc ^= 0x04c11db7;
return crc;
I have a few ESP201s that work great but there is one that works out of six.
At first the ESP201 when it stops working does so when the Wi-Fi is opened, then it falls into a reboot routine and at the limit I can no longer reprogram it. And even when it accepts programming. it does not work anymore.
Someone can help me?
