memclear
a = 1
b = 1
r1 = 16
r2 = 3
ciclo = 1
dimmer = 0
t1 = 5000
t2 = 5000
bounce = 200
io(po,r1,1)
io(po,r2,1)
interrupt 14,[inta]
interrupt 12,[intb]
interrupt 13,[intc]
interrupt 0,[intd]
interrupt 2,[inte]
interrupt 5,[intf]
[lop]
cls
wprint "Out A (On/Off) "
wprint htmlvar(a)
button "On", [Aon]
button "Off", [Aoff]
wprint "<br><br>"
wprint "Out B (On/Off) "
wprint htmlvar(b)
button "On", [Bon]
button "Off", [Boff]
wprint "<br><br>"
wprint "Out A (Pulse Time) "
wprint htmlvar(t1)
button "On", [PulseAon]
wprint "<br><br>"
wprint "Out B (Pulse Time) "
wprint htmlvar(t2)
button "On", [PulseBon]
wprint "<br><br>"
wprint "Out A and B (Cilic) A "
wprint htmlvar(a)
wprint " B "
wprint htmlvar(b)
button "On", [ciclic]
wprint "<br><br>"
wprint "Dimmer C "
wprint htmlvar(dimmer)
button "On", [dimm]
wprint "<br><br>"
wait
[Aon]
io(po,r1,0)
a = 0
returngui
wait
[Aoff]
io(po,r1,1)
a = 1
returngui
wait
[Bon]
io(po,r2,0)
b = 0
returngui
wait
[Boff]
io(po,r2,1)
b = 1
returngui
wait
[PulseAon]
io(po,r1,0)
delay t1
io(po,r1,1)
returngui
wait
[PulseBon]
io(po,r2,0)
delay t2
io(po,r2,1)
returngui
wait
[ciclic]
if ciclo = 0 then
io(po,r1,1)
a = 1
io(po,r2,1)
b = 1
ciclo = 1
goto [lop]
end if
if ciclo = 1 then
io(po,r1,0)
a = 0
io(po,r2,1)
b = 1
ciclo = 2
goto [lop]
end if
if ciclo = 2 then
io(po,r1,1)
a = 1
io(po,r2,0)
b = 0
ciclo = 3
goto [lop]
end if
if ciclo = 3 then
io(po,r1,0)
a = 0
io(po,r2,0)
b = 0
ciclo = 0
goto [lop]
end if
[inta]
if a=1 then
io(po,r1,0)
a = 0
io(po,r1,1)
a = 1
endif
'delay bounce
returngui
wait
[intb]
if b=1 then
io(po,r2,0)
b = 0
io(po,r2,1)
b = 1
endif
'delay bounce
returngui
wait
[intc]
wait
[intd]
wait
[inte]
wait
[intf]
wait
[dimm]
wait
What does your schematic look like? Do you have pullup resistors (10K or so) on all the inputs that are defined with interupt?
I have not tested your code but I would suggest you drop back and simplify it as much as possible and see how it behaves. Like just set up with one relay and one INT and then start moving forward adding more complexity and see where it breaks.
good luck
dwight
I do not understand why program run well in debug mode and bad in run mode...
In which case your script keeps re-defining the single interrupt to different pins, and only the last defined interrupt pin assignment will actually cause an interrupt, rather than having multiple pins each with their own interrupts as you were presumably expecting.
If that's the case, you would either need to keep polling the pins for change...
or perhaps use a multi-i/o port expander for your inputs, and have a port expander input change cause its interrupt output to trigger the esp's single interrupt pin to branch to an interrupt handler routine that would read the port expander inputs for what changed.
