- Sat Sep 10, 2016 3:10 pm
#54826
I know what you mean about Microsoft... I recently went for a weekend into the mountains with friends, taking my ESP-Basic dev module and a netbook with a new install of Win10 in case it rained. No other wifi signals around, and Win10 could clearly see the ESP device, but refused to connect to it. After reverting back to Win7 everything worked properly again.
I'm fed up being dictated to by MS, and have already wasted far too much of my life on them already to have much patience left to keep jumping through their hoops. So I'll be sticking with Win7 for the foreseeable future - and I'd still be running XP if they hadn't forced that upgrade on me.
I'm not sure what you've been wrestling with regarding udp though, cos we know it already works, and the udp nodes can be controlled several ways from a Windows pc on the same subnet.
I have a separate wifi router with dhcp server to provide a subnet reserved just for my ESPs. In my case I prefer isolation (I could bridge a specific node to the internet if ever necessary), but in your case you'd probably want your default gateway to point to an internet-connected router.
The only other device on my ESP subnet is my Win7 dev pc, which has wifi connection to the ESPs, plus a second wired subnet connection to internet and the rest of my intranet. Obviously the windows browser can be used to connect to an ESP in server (AP) mode. But for subnet-wide comms I originally used a windows UDP Processing script to broadcast and receive udp messages with the ESP nodes. Then cicciocb kindly made his UDP debugger utility available, which offered quicker and more convenient communications with the nodes.
But the important point is... the UDP Processing script still remains a useful alternative if ever something more specific needs to be done, because Processing offers an interface into both the windows hardware and software if required.
All the nodes I've done so far have been based on the original 'EasyNet' concept which I was developing using V2 until V3 was released. I've tried converting from V2 to V3 a couple of times, but the browser screen never worked properly again. That is not actually much of a problem for my purposes any more, because for future-proofing I now prefer the independence of non-browser contact with the ESPs. I can send any debug info I want from the ESP to the windows udp debugger utility. And I can send udp messages from the debugger utility to any named network node to trigger any appropriate tasks (commands+parameters) that they've been programmed to locally recognise and respond to.
Eg: In the case of a Sonoff Relay node called Lamp1, sending "Lamp1 Toggle" (or On or Off) from the debugger utility would cause the named node to toggle it's relay.
The node can send a udpreply acknowledgement specifically back to the sender.
In this case the sender is the debugger utility, but that's just for test and dev purposes of course, so the intention is for a remote sensing (eg: PIR or LDR) node to send the appropriate trigger command, or eventually perhaps from a mobile's AppInventor control screen.
All nodes recognise and respond to some common commands, such as BlinkIP, instructing them to blink out their IP address on their local LED.
I expect the final implementation of EasyNet to include a comms optimising facility, whereby nodes that are expected to be sending instructions to other nodes would initially broadcast a "who's there?" enquiry, and store all responding nodes IP addresses against any corresponding node names that it was specifically interested in communicating with. This would allow targeted addressing instead of network-wide broadcasting for any subsequent communications with those nodes.
It wouldn't actually take much to convert EasyNet from V2 to V3 if I don't bother trying to get the browser to display correctly like it does in V2, but it would take longer to do an effective hand-shaking mechanism for making udp comms sufficently robust and reliable. I don't think it should be hugely difficult, it's a matter of remembering each transmitted broadcast until receiving an acknowledgement, and having ability to periodically re-transmit un-acknowledged broadcasts up to a specified number of retries if necessary. Where I can see complications is in remembering multiple sent msgs to different nodes, which I think is going to need a flexible array 'holding' buffer and the ability to match up incoming acknowledgements to the array entries (bearing in mind that an incoming ack may be intended for a different node which sent the msg).
The problem is, I haven't found a satisfactory way of linking the array handling to hardware event triggers such as an incoming udp responses yet (I still haven't cracked it for a voice chip 'busy' signal to control a FIFO buffer of queued audio files).
Anyway, assuming you are using some convention like EasyNet for the ESP nodes (so that they are all sending and receiving similar 'known' format ascii msgs, eg: "Name Command [Parameters]"), you should in theory be able to use any other platform that is capable of sending and receiving ascii msgs over udp, and I know for sure it can be done with a windows machine running an appropriate script in 'Processing'.
