http://esp8266basic.com
A BASIC interpreter for your ESP
Working now on Autodrop3d. A 3d printer with automatic part ejection system. https://autodrop3d.com
Explore... Chat... Share...
martinayotte wrote:Michael, there is the library https://github.com/bblanchon/ArduinoJson, it should be already compatible with ESP, but I didn't try it myself yet.
cls
button "Exit " [Exit]
timer 30000 [check]
wait
[check]
OWMString = "api.openweathermap.org/data/2.5/weather?id=4174855&units=imperial&appid=YOUROWMAPIKEY"
a$ = wget(OWMString)
serialprintln a$
b = instr(a$,"temp")
bx = b + 6
jtemp$ = mid(a$,bx,5)
serialprint "temp found = "
serialprintln jtemp$
b = instr(a$,"pressure")
bx = b + 10
jtemp$ = mid(a$,bx,4)
serialprint "pressure found = "
b = instr(a$,"humidity")
bx = b + 10
jtemp$ = mid(a$,bx,2)
serialprint "humidity found = "
wait
[Exit]
timer 0
wprint "<a href='/'>Menu</a>"
