By viscomjim
#37538 A request... I see a few "weather widgets" using the ESP and OLEDs out there on the web. Are there any plans on incorporating a JSON parser to be able to pull required data from many of the services available out there? This would be a very cool addition.
Also, THANKS for the very recent interrupt feature! Nice touch.
Can't thank you enough for your hard work. This has allowed me to make use of the ESP much more than ever before!!!!
Go Mike!!!!
By Mmiscool
#37813 if you know of nice arduino function that dose this it would help. Been a bit busy messing with my new 3d printer. Seems I might have been neglecting this a bit.
By GengusKahn
#37839 Hi there, Parse the JSON data in the HTML using the browser resources.....
The first is for standard JSON the second is using a "constructed frame" containing the data log from SPIFFS enclosed in an html table....
These could be used to analyse and post data back....
Code: Select all <html lang="en">
 <head>
   <meta charset="utf-8">
   <title>ESP8266-Environment-Monitor</title>
 </head>
<font color="#000000"><body bgcolor="#a0dFfe"><meta name="viewport" content="width=device-width, initial-scale=1.0, user-scalable=yes">
   <h2>Environmental Sensor Readings</h2>
   <h2>Using an ESP8266 with 2 DHT11<BR>& 1 DS18B20 Environment Sensors<BR><BR> ♂♀♪♫☼►</h2>
<BR><BR><a href="http://esp8266.com/">Find out how this is done Visit ESP8266.COM Support Forum</a><BR><BR><BR>
   <script src="http://ajax.googleapis.com/ajax/libs/jquery/1.5/jquery.min.js"></script>
<div style="float:left;">
<div id="ESPS001" style="float:left;"><a href="https://freeboard.io/board/ISfNF7">Freeboard IO Dashboard</a><BR><a href="http://82.5.78.180:92/jsread">GET JSON Frame</a><BR><a href="http://82.5.78.180:92/diag">Device Information Page</a><BR>Readings from<BR>ESP8266 Sensors </div>
    <div id="container">
  <style type="text/css">
  #container { height: 10%; width: 10%; display: table; }
  #gauge_div { width: 100px; margin: 0 auto; }
ESPS001, th , td {
    border: 1px solid cyan;
    border-collapse: collapse;
    padding: 5px;
</style>
Google Gauge Via Thingspeak JSON Frame
      <div id="inner">
        <div id="gauge_div"></div>
      </div>
    </div>
</div>
 <script>
$.ajax({
    // get the data from ESP8266 sensors via CORS Enabled JSON Frame
    // CORS explaination found here...
    //   https://developer.mozilla.org/en-US/docs/Web/HTTP/Access_control_CORS
    type: "GET",
    url: "http://82.5.78.180:92/jsread",
    async: false,
    beforeSend: function(x) {
     if(x && x.overrideMimeType) {
      x.overrideMimeType("application/j-son;charset=UTF-8");
// Now parse the JSON frame for valid "Key:Value" pairs, as many as you have formed in your sketch the list does not have a size
// Repeated keys will be omitted...
 dataType: "json",
 success: function(data){
     var items = [];
     $.each(data, function(key, val) {
       items.push("<tr><td> "+ key +" </td><td> " + val + " </td></tr> ");
     $('.my-new-list').remove();
     $('<ul/>', {
       'class': 'my-new-list',
       html: items.join('')
// Now place the parsed data into the div for display, or do something with the data in the ESP Sketch...
     }).appendTo('#ESPS001');
   </script>
  <script type='text/javascript' src='https://ajax.googleapis.com/ajax/libs/jquery/1.9.1/jquery.min.js'></script>
<script type='text/javascript' src='https://www.google.com/jsapi'></script>
<script type='text/javascript'>
  // set your channel id here
  var channel_id = 75183;
  // set your channel's read api key here if necessary
  var api_key = '';
  // maximum value for the gauge
  var max_gauge_value = 50;
  // name of the gauge
  var gauge_name = 'DS18-Temp';
  // global variables
  var chart, charts, data;
  // load the google gauge visualization
  google.load('visualization', '1', {packages:['gauge']});
  google.setOnLoadCallback(initChart);
  // display the data
  function displayData(point) {
    data.setValue(0, 0, gauge_name);
    data.setValue(0, 1, point);
    chart.draw(data, options);
  // load the data
  function loadData() {
    // variable for the data point
    var p;
    // get the data from thingspeak in the form of a rather large JSON Frame
    // containing lots of useful data interaction for the ESP8266 sketch
    $.getJSON('https://api.thingspeak.com/channels/' + channel_id + '/feed/last.json?api_key=' + api_key, function(data) {
      // get the data point from within the Thingspeak JSON Frame
      p = data.field5;
      // if there is a data point display it
      if (p) {
       // p = Math.round((p / max_gauge_value) * 100);
        displayData(p);
  // initialize the chart & Request data after the Sensor data list is populated
  function initChart() {
    data = new google.visualization.DataTable();
    data.addColumn('string', 'Label');
    data.addColumn('number', 'Value');
    data.addRows(1);
    chart = new google.visualization.Gauge(document.getElementById('gauge_div'));
    options = {width: 300, height: 300, min: 0, max: 50, redFrom: 32, redTo: 50, yellowFrom:0, yellowTo: 17, minorTicks: 10};
    loadData();
    // load new data every 15 seconds
    setInterval('loadData()', 15000);
    // Thingspeak Matlab Frame, this is directly pasted from the html provided by the Thingspeak Page....
</script>
<BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR>
Thingspeak Data Visualisation via Matlab Chart
<div style="float:none;"><iframe width="450" height="375" style="border: 1px solid #cccccc;" src="http://api.thingspeak.com/apps/matlab_visualizations/41029" ></iframe>
<BR>environmental.monitor.log@gmail.com<BR><FONT SIZE=-2>ESP8266 With Various Sensors<BR><FONT SIZE=-2>Compiled Using ver. 2.0.0-rc2, built December, 2015<BR></div>
</body>
</html>
This is to pull the data logged from the previous 24 hours into a table....
Code: Select all<html lang="en">
 <head>
 </head>
   <h2>ESP8266's Remote data log from SPIFFS<BR><BR> ♂♀♪♫☼►</h2>
<div id="ESPS001" style="float:top;"><a href="http://82.5.78.180:83/diag">Device Information Page</a><BR><a href="https://freeboard.io/board/dRP7R6">Freeboard IO Dashboard</a><BR><a href="http://82.5.78.180:83/tread">GET Datalog - JSON Frame containing HTML Table</a><BR><a href="http://82.5.78.180:83/jsread">GET JSON Frame</a><BR>Sensors from<BR>ESP8266 Number 1 </div>
<div id="container" style="float:left;">
  #container { height: 100%; width: 100%; display: table; }
ESPS001, th , td {
    border: 1px solid purple;
    padding: 2px;
</style>
</div>
 <script>
$.ajax({
    type: "GET",
    url: "http://82.5.78.180:83/tread",
    async: false,
 dataType: "json",
     var items = [];
       items.push(key + val);
     $('<ul/>', {
     }).appendTo("#container");
   </script>
</body>
</html>
