var ssid = "YourSSID";
var pass = "YourPassword";
var ApiKey = 'YourApiKey';
var altitude = 188; // current altitude in m
var mode = 2; //resolution of sensor conversion (0-3)
var afdt = 1; //present numbers after dot
var press = 0; //pressure
var temp = 0; //temperature
var peri = 15; //period of reading sensor in sec.
var cl = 0; // SCL to GPIO0
var da = 2; // SDA to GPIO2
console.log('connecting to wifi');
ESP8266WiFi.init();
ESP8266WiFi.connect(ssid, pass, function() {
console.log('connected to wifi');
var ipInfo = ESP8266WiFi.getIPInfo();
print("Current IP address is: " +
ESP8266WiFi.getAddressAsString(ipInfo.ip) + ':' +
ESP8266WiFi.getAddressAsString(ipInfo.netmask));
function aftDot(number, ad) //Formatting numbers.
return (number.toString()).substr(0, (number.toString()).indexOf('.') + 1 + ad);
function readBMP() //read BMP85 or BMP180 sensor
var bmp = require("BMP085").connect(I2C1, mode);
bmp.getPressure(function(d) {
press = aftDot(bmp.getSeaLevel(d.pressure, altitude) / 100, afdt);
temp = aftDot(d.temperature, afdt);
console.log("\nPressure at sea level: " + press + " hPa");
console.log("Temperature: " + temp + " C");
return;
function sendTs(press, temp) {
var http = require("http");
http.get({
host: "184.106.153.149",
port: 80,
path: '/update?key=' + ApiKey + '&field3=' + press + '&field4=' + temp
function(response) {
print("get callback!");
response.on('data', function(data) {
print(data);
response.on('close', function() {
print("The response connection closed");
I2C1.setup({
scl: cl,
sda: da
function repeat() {
readBMP(), sendTs(press, temp), setTimeout(repeat, peri * 1000);
repeat();
