If you use the Espruino Web Ide, the baudrate is set to 9600 by default.
It should be changed to 115.200.
You do that in Settings->communication
Explore... Chat... Share...
Erni wrote:I just used the official Espruino Web IDE.
I flashed the binaries to a ESP-01 and was up and running.
Here is my blink example:Code: Select allvar GPIO2 = new Pin(2);
var toggle=1;
setInterval(function() {
toggle=!toggle;
digitalWrite(GPIO2, toggle);
}, 500);
I also got the HTTP responder workin:
https://github.com/esp8266-espruino/esp ... 07-Samples
