I tried your webserver with the latest binaries, and it is running fine.
Sometimes you have to do the upload twice, I don't know why (the first time you get a reset, and the next time it works)
Explore... Chat... Share...
led on
{ "free": 747, "usage": 276, "total": 1023, "history": 115 }
led off
led on
led off
led on
led on
led on
ASSERT(pSocketData->currentTx == ((void *)0)) FAILED AT libs/network/esp8266/network_esp8266.c:945
#1[r1,l2] Object {
#2[r1,l2] Name String [1 blocks] "ÿ" #3[r1,l2] Object {
#6[r1,l2] Name String [2 blocks] "timers" #8[r2,l1] Array(0) [ ]
#9[r1,l2] Name String [2 blocks] "watches" #11[r2,l1] Array(0) [ ]
#14[r1,l2] Name String [1 blocks] "net" #51[r1,l3] String [2 blocks] "\x04\x00\x00\x00\x00ÿÿÿ"
#22[r1,l2] Name String [2 blocks] "history" #24[r1,l1] Array(27) [
#46[r1,l2] Name Integer 2 #42[r1,l1] String [6 blocks] "ESP8266WiFi.beAccessPoint('ESP_1610')"
#47[r1,l2] Name Integer 4 #18[r1,l1] String [3 blocks] "ESP8266WiFi.init();"
#60[r1,l2] Name Integer 12 #65[r1,l1] String [4 blocks] " var GPIO2 = new Pin(2);"
#82[r1,l2] Name Integer 13 #85[r1,l1] String [5 blocks] " var http = require(\"http\");"
#170[r1,l2] Name Integer 14 #181[r1,l1] String [81 blocks] " var httpSrv = http.createServer(function(request, response) {\n print(process.memory());\n\n response.write(\"<html><body>\");\n if (request.url == \"/on\") {\n response.write(\"<b>LED is on</b>\");\n digitalWrite(GPIO2, false);\n print (\"led on\");\n } else if (request.url == \"/off\") {\n response.write(\"<b>LED is off</b>\");\n print (\"led off\");\n digitalWrite(GPIO2, true);\n } else {\n response.write(\"Welcome to ESP with JS\");\n }\n response.end(\"<br><a href='/on'>Led ON</a><br><a href='/off'>Led OFF</a></body></html>\");\n });"
#270[r1,l2] Name Integer 15 #271[r1,l1] String [4 blocks] " httpSrv.listen(80);"
#39[r1,l2] Name Integer 26 #313[r1,l1] String [4 blocks] "ESP8266WiFi.getState()"
#80[r1,l2] Name String [2 blocks] "modules" #91[r1,l1] Object {
#81[r1,l2] Name String [1 blocks] "http" #92[r2,l1] ...
#276[r1,l2] Name String [2 blocks] "HttpS" #278[r1,l1] Array(1) [
#279[r1,l2] Name Integer 0 #264[r3,l1] ...
#301[r1,l2] Name String [2 blocks] "HttpSC" #304[r1,l2] Array(10) [
#296[r1,l3] Name Integer 9 #369[r1,l2] Object {
#370[r1,l2] Name String [2 blocks] "__proto__" #295[r2,l1] ...
#349[r1,l2] Name String [1 blocks] "type"= int 1
#302[r1,l2] Name String [1 blocks] "res" #405[r1,l2] Object {
#323[r1,l2] Name String [2 blocks] "__proto__" #298[r2,l1] ...
#337[r1,l2] Name String [1 blocks] "code"= int 200
#342[r1,l2] Name String [1 blocks] "hdr" undefined
#329[r1,l2] Name String [1 blocks] "dSnd" #384[r1,l2] String [19 blocks] "HTTP/1.0 200 OK\r\nServer: Espruino 1v81.615\r\n\r\n<html><body><b>LED is on</b><br><a href='/on'>Led ON</a><br><a href='/off'>Led OFF</a></body></html>"
#368[r1,l2] Name String [2 blocks] "close" #350[r1,l1] Bool true
#409[r1,l2] Name String [1 blocks] "svr" #264[r3,l1] ...
#359[r1,l2] Name String [1 blocks] "sckt"= int 11
#412[r1,l2] Name String [1 blocks] "dRcv" #382[r1,l1] String [1 blocks] ""
#400[r1,l2] Name String [2 blocks] "headers" #419[r1,l1] Object {
#292[r1,l2] Name String [1 blocks] "Host" #335[r1,l1] String [2 blocks] "192.168.4.1"
#333[r1,l2] Name String [2 blocks] "User-Agent" #360[r1,l1] String [10 blocks] "Mozilla/5.0 (Windows NT 10.0; WOW64; rv:40.0) Gecko/20100101 Firefox/40.0"
#325[r1,l2] Name String [2 blocks] "Accept" #390[r1,l1] String [9 blocks] "text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"
#364[r1,l2] Name String [3 blocks] "Accept-Language" #318[r1,l1] String [4 blocks] "de,en-US;q=0.7,en;q=0.3"
#317[r1,l2] Name String [3 blocks] "Accept-Encoding" #371[r1,l1] String [3 blocks] "gzip, deflate"
#305[r1,l2] Name String [2 blocks] "Referer" #366[r1,l1] String [4 blocks] "http://192.168.4.1/on"
#374[r1,l2] Name String [2 blocks] "Connection" #334[r1,l1] String [2 blocks] "keep-alive"
#331[r1,l2] Name String [2 blocks] "method" #398[r1,l1] String [1 blocks] "GET"
#406[r1,l2] Name String [1 blocks] "url" #415[r1,l1] String [1 blocks] "/on"
#418[r1,l2] Name String [1 blocks] "hdrs" #341[r1,l1] Bool true
#16[r1,l2] Name String [2 blocks] "ESP8266WiFi" #17[r1,l1] NativeFunction 0x402223ac (1) { }
#25[r1,l2] Name String [2 blocks] "ESP8266State" undefined
#64[r1,l2] Name String [2 blocks] "GPIO2" #83[r1,l1] Pin 2
#76[r1,l2] Name String [1 blocks] "Pin" #66[r2,l1] NativeFunction 0x40234148 (9) {
#45[r1,l2] Name String [2 blocks] "prototype" #73[r1,l1] Object {
#78[r1,l2] Name String [2 blocks] "constructor" #66[r2,l2] ...
#84[r1,l2] Name String [1 blocks] "http" #92[r2,l1] NativeFunction 0x40222420 (0) { }
#172[r1,l2] Name String [2 blocks] "httpSrv" #264[r3,l1] Object {
#265[r1,l2] Name String [2 blocks] "__proto__" #261[r2,l1] Object {
#262[r1,l2] Name String [2 blocks] "constructor" #258[r1,l1] NativeFunction 0x40222410 (1) {
#259[r1,l2] Name String [2 blocks] "prototype" #261[r2,l2] ...
#268[r1,l2] Name String [1 blocks] "type"= int 1
#267[r1,l2] Name String [2 blocks] "#onconnect" #167[r1,l1] Function {
#166[r1,l2] Name Param "request" undefined
#164[r1,l2] Name Param "response" undefined
#257[r1,l2] Name String [1 blocks] "ÿcod" #160[r1,l1] String [73 blocks] "{\n print(process.memory());\n\n response.write(\"<html><body>\");\n if (request.url == \"/on\") {\n response.write(\"<b>LED is on</b>\");\n digitalWrite(GPIO2, false);\n print (\"led on\");\n } else if (request.url == \"/off\") {\n response.write(\"<b>LED is off</b>\");\n print (\"led off\");\n digitalWrite(GPIO2, true);\n } else {\n response.write(\"Welcome to ESP with JS\");\n }\n response.end(\"<br><a href='/on'>Led ON</a><br><a href='/off'>Led OFF</a></body></html>\");\n }"
#280[r1,l2] Name String [1 blocks] "port"= int 80
#281[r1,l2] Name String [1 blocks] "sckt"= int 1
#275[r1,l2] Name String [2 blocks] "httpSRq" #62[r2,l1] NativeFunction 0x40222400 (1) {
#285[r1,l2] Name String [2 blocks] "prototype" #295[r2,l1] Object {
#48[r1,l2] Name String [2 blocks] "constructor" #62[r2,l2] ...
#290[r1,l2] Name String [2 blocks] "httpSRs" #288[r2,l1] NativeFunction 0x402223f0 (1) {
#77[r1,l2] Name String [2 blocks] "prototype" #298[r2,l1] Object {
#294[r1,l2] Name String [2 blocks] "constructor" #288[r2,l2] ...
#347[r1,l2] Name String [2 blocks] "process" #348[r1,l1] NativeFunction 0x402224a0 (1) { }
load 0x40100000, len 30648, room 16
tail 8
chksum 0x4f
load 0x3ffe8000, len 2108, room 0
tail 12
chksum 0x00
ho 0 tail 12 room 4
load 0x3ffe8840, len 28804, room 12
tail 8
chksum 0xb6
csum 0xb6
nîsys=68011 rtc=50447953
don't use rtc mem data
