Moderator: Mmiscool
By forlotto
#47067 Yes you can pin2 is one wire...
There is an example of this temp sensor in the programming examples section...
And if I recall correct the one wire bus supports several devices I am not sure as to what the hard limit is on the one wire bus for the esp8266 but I would assume it depends on the power and hardware I know a 1wire bus is able to search out and find 75 devices per second.
But I am near 99.9% sure 2 temp sensors should not be an issue at all.
Enjoy
