I tried many ways to send some symbols characters to the Oled display. Even the degrees symbol ASCII (176) don't showed right in the display.
I found one Arduino library to SSD1306 that correct the characters sent to the Oled display, used with ESP8266, and with many fonts.
The author had problem exactly with UTF-8, then he correct the library code to support Extended Ascii codes. This is not the final solution, but helps a lot and makes the display more usable.
I don't now if it is possible use this library , but at least you can see the code that correct this situation. Maybe one fix can be made.... , and this will help many people that don't use English.
This is the site :
http://blog.squix.org/2015/12/esp8266-f ... es-in.html
And this is the library :
https://github.com/squix78/esp8266-oled-ssd1306
