By loeten
#35429 Hello everybody! I finished my setup and i was just flashing the ESP8266Basic.cpp.bin via esptool.py
I see the device as "ESP in my mobile's WiFi scan, and i can also connect and i see [VARS], [EDIT] etc - so the normal user interface as it should be.
However, when i try to do settings (AP Mode, Log In Key) and save, then go to [var] and back to [settings] - the settings disappear - all fields empty.. did i misunderstood?
I was expecting, when i reboot, i should see a WiFi like "myESP" what i was using as Name in AP settings - no?
I am Using an ESP-01 black (1MB) and the latest build (160MHz) from Github..
Also, i am able to enter source code in [Edit], but in [run] it just says "Done.."
By Mmiscool
#35430 You must save your code to upload it before hitting run.
The settings page should save the settings. Try hitting the format button on the settings gs page and see if that clears up the issue.
By loeten
#35431 :-) I did save the source and the browser popped also up a message box "saved". But no luck still, also format did not help.
Maybe it writes too fast / cannot write to the flash? Should i try a different .bin? (if yes, which one)?
