- Wed Feb 01, 2017 4:55 pm
#61892
Using the critical advice above, I was able to use the Arduino IDE 1.8.1 to build ESP8266 Basic, after I copied all the libraries from the source directory from git hub. That is all the libraries that didn't over write all the ones I already had, that have been carefully upgraded to their latest releases inside the Arduino lib manager.
There was a lot of understandable complaining about multiple definitions of all sorts of things, many warnings and complaints of sorts of arcane issues, but this is what resulted.
Using library arduinoWebSockets at version 2.0.2 in folder: C:\Users\Randall\Documents\Arduino\libraries\arduinoWebSockets
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\Randall\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi
Using library Hash at version 1.0 in folder: C:\Users\Randall\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Hash
Using library ESP8266mDNS in folder: C:\Users\Randall\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266mDNS (legacy)
Using library ESP8266WebServer at version 1.0 in folder: C:\Users\Randall\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer
Using library Wire at version 1.0 in folder: C:\Users\Randall\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire
Using library Servo at version 1.0.2 in folder: C:\Users\Randall\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Servo
Using library OneWire at version 2.3.2 in folder: C:\Users\Randall\Documents\Arduino\libraries\OneWire
Using library DallasTemperature at version 3.7.6 in folder: C:\Users\Randall\Documents\Arduino\libraries\DallasTemperature
Using library ESP8266HTTPClient at version 1.1 in folder: C:\Users\Randall\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266HTTPClient
Using library LiquidCrystal_I2C at version 1.1.2 in folder: C:\Users\Randall\Documents\Arduino\libraries\LiquidCrystal_I2C
Using library Adafruit_NeoPixel at version 1.0.6 in folder: C:\Users\Randall\Documents\Arduino\libraries\Adafruit_NeoPixel
Using library SoftwareSerial at version 1.0 in folder: C:\Users\Randall\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SoftwareSerial
Using library SPI at version 1.0 in folder: C:\Users\Randall\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI
Using library IRremoteESP8266 at version 1.0.0 in folder: C:\Users\Randall\Documents\Arduino\libraries\IRremoteESP8266
Using library expression_parser_string in folder: C:\Users\Randall\Documents\Arduino\libraries\expression_parser_string (legacy)
Using library DHT_sensor_library at version 1.2.3 in folder: C:\Users\Randall\Documents\Arduino\libraries\DHT_sensor_library
Using library pubsubclient-master at version 2.6 in folder: C:\Users\Randall\Documents\Arduino\libraries\pubsubclient-master
Sketch uses 427279 bytes (40%) of program storage space. Maximum is 1044464 bytes.
Global variables use 46624 bytes (56%) of dynamic memory, leaving 35296 bytes for local variables. Maximum is 81920 bytes.
I guess a successful compile, have not tested in other way than just getting it to build.
What a great project and learning opportunity! Also immediately applicable in my classroom, as I can't attach to anything by policy, network or usb port.
Best,
Randy
