By cwilt
#36338 Which display are you working with?
Do you have a DSO, bus pirate, or other to watch communication between the ESP and display? Maybe the pull up needs to be different.
By viscomjim
#36340 I am using this display...
https://www.adafruit.com/products/1269
And it works just fine on the uMite. I will try a few different resistors just to check though.
Unfortunately my scope is at work. I tried the oled display using Mikes code and it works fine, so I can only assume at this point without the scope that the I2C is working. I will keep playing...
Tried different resistors from 1.5k to 10k. No change. Will keep trying code things...
By viscomjim
#36346 I've been trying this on a esp-01 using GPIO0 as SDA and GPIO2 as SCL without luck. I would like to try my nodeMCU board, but am not sure which pins to use. GPIO 0 is shown as pin D3 and GPIO 2 is shown as D4. Is this correct?
By cwilt
#36347
viscomjim wrote:I've been trying this on a esp-01 using GPIO0 as SDA and GPIO2 as SCL without luck. I would like to try my nodeMCU board, but am not sure which pins to use. GPIO 0 is shown as pin D3 and GPIO 2 is shown as D4. Is this correct?
correct
