AT-based firmware detected.
AT+GMR
AT version:1.3.0.0(Jul 14 2016 18:54:01)
SDK version:2.0.0(656edbf)
compile time:Jul 19 2016 18:44:44
OK
http://www.esp8266.com/viewtopic.php?f=40&t=6732#p34663
forlotto wrote: ...
NodeMCU/Basic Wifi Dev Board guide for MMISCOOL Basic IDE
If you have a nodemcu read the following flashing steps.
FLASH THE NODE MCU WITH BASIC FIRMWARE:
Download the Basic Flasher Utility Latest Version: http://www.esp8266basic.com/download.html
Open the utility
Set your Com Port
Select 4MB Flash
He makes it so easy now in version 3.17 you just hook up your nodemcu or espbasicdevkit and hit flash firmware button in the software and viola instantly starts flashing no holding down buttons or fumbling around just hit flash firmware and go!
With LoLin NodeMCU V3 Dev Board I get:
error: Failed to open COM5
error: espcomm_open failed
error: espcomm_upload_mem failed
Edit:
I noticed Build\4M\ESP8266Basic.cpp.bin file in the installation so I just flashed that with ESP8266Flasher. Seems to have worked.
