I use the ' (single quote) to temporarily disable a line of code, but the code still seems to read the line that follows.
Explore... Chat... Share...
'Timer blink test
timer 1000, [blipLED] 'This statement calls a subroutine to blink an LED for ~100ms
wait
[blipLED] 'Blink subroutine
io(po,16,1)
'print "On" 'Bad idea on such a tightly timed subroutine, very delayed print
delay 100
io(po,16,0)
'print "Off" 'Bad idea on such a tightly timed subroutine, very delayed print
wait
endIt takes about 20-25 seconds for home assistant c[…]
