Who is the developer?
What is the source code under BASIC?
What is the difference between BASIC , NODEMCU, Lua , ESPRUINO
As far as I know The Lua is like an OS for the devices ?
Nodemcu is based on Lua
etc.
Explore... Chat... Share...
Can you tell me where can i read more about the ESP - BASIC:
This is true. Similarly the esp basic firmware is like an OS. It manages files. Allows you to edit basic programs and communicate with your web browser
bool ConnectToTheWIFI(String NetworkName, String NetworkPassword, String NetworkStaticIP, String NetworkGateway, String NetworkSubnet)
WiFi.mode(WIFI_AP_STA);
byte numberOfAtempts = 0;
int str_len = NetworkName.length() + 1;
char ssid[str_len];
NetworkName.toCharArray(ssid, str_len);
str_len = NetworkPassword.length() + 1;
char password[str_len];
NetworkPassword.toCharArray(password, str_len);
// Connect to WiFi network
WiFi.begin(ssid, password);
