I would like to toggle a flag on a button push.
btn = io(pi,3)
if btn = 0 then
if flag = 0 then flag = 1
if flag = 1 then flag = 0
endifis there a better / simpler way??
thanks in advance
dwight
Explore... Chat... Share...
btn = io(pi,3)
if btn = 0 then
endiftoggle = 1
button "switch", [switch]
wait
[switch]
toggle = ! toggle
io(po,d2,(abs(toggle))
wait
ledpin = 1 'Use ledpin as your flag variable
buttonpin = 0 'Uses gpio00 flashing button by default, change to suit (needs pullup resistor).
interrupt buttonpin, [PRESSED]
wait
[PRESSED]
if io(laststat,buttonpin) = 0 then gosub [TOGGLE] 'else do nothing
wait
[TOGGLE]
if io(laststat,ledpin) = 1 then io(po,ledpin,0) else io(po,ledpin,1)
returnIt takes about 20-25 seconds for home assistant c[…]
