If this is possible, can you give a short example of code for maybe one button just to see how it is done?
Thanks!!!!!
Explore... Chat... Share...
memclear
cls
' this is the default value for pwm out
pdef = 512
' this is the pin defined as pwm output
pwo 13 pdef
' this is the slider
wprint |<input type="range" id="dimmer" oninput="setPWM()" onclick="setPWM()" min="0" max="1023" value="| & pdef & |"/>|
'this is the javascript "ajax" code
fun$ = |function setPWM() {|
fun$ = fun$ & |lum=document.getElementById("dimmer").value;|
fun$ = fun$ & |window.event.returnValue = false;|
fun$ = fun$ & |var xmlHttp = new XMLHttpRequest();|
fun$ = fun$ & |xmlHttp.open("GET", "msg?pwm=" + lum, false);|
fun$ = fun$ & |xmlHttp.send(null);|
fun$ = fun$ & |return xmlHttp.responseText;}|
' this is where the code is inserted into the html
wprint "<script>" & fun$ & "</script>"
'this is where the prog will jump on slider change
msgbranch [message]
wait
[message]
msgget "pwm" mess
'uncomment this line to see the value received
'serialprintln mess
pwo 13 mess
wait
