eriksl wrote:From what I've read/understand:
1: There is one timer available through the "os" layer, you can have it call a function every x milliseconds (or one shot), also microseconds resolution seems to be available with a new undocumented sdk function. It's not a "timer" in the common microcontroller sense.
2: Quite a lot, I think, from what I read. What do you need?
3: All GPIO's can be connected to the one generic PWM generator, all with their own duty cycle. So far the good news. The bad news: the resolution is only 8 bits and there are not that may pins available (about six). Also all PWM output share the same frequency (which doesn't have to be a real problem imho).
4: Only one analog input. But that's no problem. Actually all low-end microcontroller only have one analog input, which is multiplexed internally using an analog CMOS switch (like CD4066). You can add something like that yourself, using some GPIO's as input select. I've been using that method for years.
Thanks for proper reply and my bad if created duplicate topic. Lets find it.
First of all, I been using nodemcu firmware. What about you ?
1. One timer, I see. But I don't get what nodemcu wiki mentioned id: 0-6
https://github.com/nodemcu/nodemcu-firm ... n#tmralarm
2. This particular feature is like for I need to auto-on/auto-off something after an hour or so.
3. But nodemcu doc says only 3 pins at most.https://github.com/nodemcu/nodemcu-firmware/wiki/nodemcu_api_en#pwmsetup
4. Yes one analog Tout as I see only available in ESP-07 and ESP-12. That is enough for my purpose. By the way you mean add GPIO expander to it. What method you using.
Thanks
