elektronika_ba wrote:Ok thanks to both!
What OS is this btw? - I am asking because I hope there is a better documentation then the one in SDK_v0.9.pdf file.
curruently , no rtos is implemented
Explore... Chat... Share...
elektronika_ba wrote:I was wondering, does anyone know where does function os_printf output to?
mog wrote:elektronika_ba wrote:I was wondering, does anyone know where does function os_printf output to?
Hi,
I was wondering the same thing and it turns out that in my case the output is sent via TX pin from ESP8266. I've been using FTDIFiend and unfortunately for 74880 baud rate it outputs garbage but using a logic analyser I was able to actually get the os_printf output show up as ASCII. Maybe there is a way to change baud rate used by os_printf ? I haven't yet found how to do it.
0ff wrote:os_printf will output to the "system" out, that's normally on GPIO2.
You can change that withCode: Select allos_install_putc1((void *)uart0_write_char);
(You'd need to define uart0_write_char if I'm not mistaken)
