Chat freely about anything...
By jqdoumen
#9780 Tried to update the firmware with the CIUPDATE command, and got stuck with a non-functional blue light blinking ESP8266.
Downloaded esptool, connected GPIO2 to 3.3V and GPIO0 to ground, booted up and executed the esptool as follows (with resulting output).
$ sudo esptool.py --port /dev/tty.usbmodem1451 write_flash 0x000000 Firmware.bin
Connecting...
File "/usr/local/bin/esptool.py", line 5, in <module>
pkg_resources.run_script('esptool==0.1.0', 'esptool.py')
File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/pkg_resources.py", line 492, in run_script
self.require(requires)[0].run_script(script_name, ns)
File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/pkg_resources.py", line 1357, in run_script
exec_(script_code, namespace, namespace)
File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/pkg_resources.py", line 47, in exec_
exec("""exec code in globs, locs""")
File "<string>", line 1, in <module>
File "/Library/Python/2.7/site-packages/esptool-0.1.0-py2.7.egg/EGG-INFO/scripts/esptool.py", line 471, in <module>
File "/Library/Python/2.7/site-packages/esptool-0.1.0-py2.7.egg/EGG-INFO/scripts/esptool.py", line 149, in connect
Exception: Failed to connect
Have this on two Macs ... What am I overlooking?
By jodahm
#12976 I had the same issue with the cloud firmware update, after 2 days of trying different solutions I luckily found my own and I recover the ESP-01 that had the problem, so here my solution:
1- use an external 3.3 Volt Source, I am using a DC wall adapter and a 3.3V regulator with 1Amp max current.
2- I have an USB,FTDI Xbee adaptor, TX to TXD on the ESP, RX to RXD on the ESP and Ground with the Ground of the external supply.
3- An electrolytic capacitor of 470uF between VCC and GND of the ESP
4- I used the ESPTOOL python script and here the command I used:
joe@Y480:~$ ./esptool.py --baud 4800 -p /dev/ttyUSB0 write_flash 0x000000 Firmware.bin
I had to send the command two times to make it go beyond 0% and resetting power after it failed at 87%, if this solution does not work, try changing the baud rate and look with which one the blue led blinks after you press enter, that is how I found 4800bps.
hope this will help with yours
