I am looking to build a circuit that when pulled high momentarily will stay high until another event pulls it low.
I think this is called a latching circuit but I'm not 100%
The reason is I want to use an ESP8266 either 01 or 03 with a tilt sensor, when tilted it will connect to the WiFi and send a Prowl alert to my iPhone. This is going to run off batteries so I need to shut the ESP down to minimise drain.
I could use an ATTiny85 to do this, pull CHP_PWD low, send the 85 to sleep and when it wakes on interrupt pull CHP_PWD high until it get's a signal on another IO pin from the ESP to say shut down again.
I was wondering however if there are any kind of passive circuits that could do this with even less power than an ATTiny85 in it's lowest possible sleep mode.
I realise it's not specifically ESP related but it might spark an idea for someone else trying to run on batteries.
Regards
Matt
