flashing totally different FW Clears what ever the issue is..
ie try AT FW, ESP-Basic FW, NodeMCU 0.9.6
Explore... Chat... Share...
John Miller wrote:Thanks for the help to both of you.
If GPIO 02 is set to HIGH the blue LED won't flash once although data is transmitted heavily over TX (occurs in operation mode with GPIO 0 HIGH and 15 LOW). If GPIO 2 is disconnected during operation, the LED starts to flash again. This isn't normal, right? Maybe a breakdown between GPIO02 and TX?
Thanks for the utility. It will come in handy in the future. I think this ESP is broken.
